07-15-2024 10:44 PM
My canon rebel t5 is showing a screen that says "Firmware update program, update file cannot be found. Please check the memory card and reload the battery and try again." I have done this so many times and nothing works, I don't know what to do and I need help!
07-16-2024 04:27 AM - edited 07-16-2024 04:28 AM
Hi and welcome to the forum:
Oddly, this sounds very familiar and I could swear there is an almost identical post somewhere, but whatever...
As per the instructions, you must download a compressed version of the update file to a computer and unpack it. If you are using a Windows computer, you need to run the Winzip file to unpack and reveal a file with an .FIR extension. On a Mac, I believe this is done transparently. You copy the FIR file to the root directory of a cleanly formatted, full-size SD card and install that in the camera. When you initiate the firmware function, it should then see the update and allow you to complete the process. Make sure you have a fully-charged battery for this and follow the instructions on screen.
