LP-E6P battery compatibility with EOS 90D
Vivachii
Hi, I have an EOS 90D and I saw that the LP-E6N/H is no longer sold, but that the LP-E6P is the successor.
Is this battery compatible with my 90D? I've read conflicting info and want to make absolute sure before I buy it.
Thank you!
Greetings ,
The 90D is compatible with the LP-E6P battery.  It shares similar specifications to the original battery offered with the 90D except it has a higher continuous discharge rate of 6 amps. It is 100% compatible.  If you are not running the latest firmware version v1.1.1 (released in 2019) I'd upgrade to it.
Also note if you look under accessories, batteries and grips on the page I referenced below the battery is listed as compatible.  It's always best to visit the Canon USA website and not sources like Reddit or Facebook for accurate information.
Canon Support for EOS 90D | Canon U.S.A., Inc. https://share.google/WZ9KB58Wv0pMf6n33
2 REPLIES 2
zakslm
Mentor
Mentor
Vivachii,
I went to the support page for the 90D at usa.canon.com and they show the LP-E6P battery as the replacement battery.
https://www.usa.canon.com/support/p/eos-90d
Hope this helps!
LZ
Greetings ,
