02-09-2024 11:57 PM
Hi, I was just wondering if it was possible to charge an LP-E17 battery with an LC-E10 charger. I’ve searched up everywhere to no avail. Pls help!
02-10-2024 01:18 AM
That battery calls for a LC-E17 charger.
The charger that comes with the R6 (referenced in your post) is the LC-E6.
The LC-E10 supports the LP-E10 (battery) which is used in the T3, T5, T6, T7, and T100.
02-10-2024 11:33 AM
Canon chargers are keyed, so that the wrong battery won't even fit into the charger.
09-15-2024 03:03 AM
FYI: The LP E17 battery does actually fit into the LC E10 charger btw...
its a tad smaller. Not saying you should charge it, just replying to your comment. Peace out.
Thanks
09-15-2024 03:09 AM
Btw It will not charge as the pin out contacts do not line up. Thanks
