02-21-2024
04:07 PM
04:12 PM
Hi, could I purchase a cf to sd adapter like this one and use it inside of the camera with an sd card in it, or would I have to get a cf card on its own?
[Commercial link removed in accordance with Community guidelines and replaced with screenshot to serve as visual aid.]
02-21-2024 04:30 PM
I would not. Using adapters typically leads to all types of issues. Furthermore, this is being sold on Amazon by some "chenyang Store". Who knows what that is and if this would even work.
If you need a CF card, get one from a reputable store that sells camera gear such as B&H Photo and Adorama to name a couple.
02-21-2024 04:30 PM
02-21-2024 04:32 PM
Hi an welcome
Cameras do not work well with adapted cards. If you want to be sure of reliability I would recommend getting the correct card.
02-21-2024 05:07 PM
CF-to-SD adapters, like the one shown, can't be used for one simple reason, even if you wanted to try it.......the SD card sticks out the side of the adapter. It will not even fit into the camera!
02-26-2024 11:52 AM
Thanks
