11-30-2021 02:26 PM - edited 12-01-2021 12:43 AM
11-30-2021 02:38 PM - edited 11-30-2021 02:42 PM
Are you using full-sized SD cards, or micro-SD cards? Always best to use full-sized cards.
Page 240 of the User Manual has some troubleshooting steps, but I believe you already did all you could (manual mostly states to try a different card).
It could be that the camcorder itself is failing. You can call Canon to look into a repair.
11-30-2021 03:51 PM
I figured that might be the only explanation, but wanted to check reliable sources. Thank you.
