t6 cannot update firmware
I have tried using bth methods of uodating the firware. When I load the firmware onto the card, the camera wont find the file. When I use the EOS Utility, it will not download from an exterior file.
The message you are trying to access is permanently deleted.
Aloha from Honolulu,I just upgraded from an 80D to an R5.I went for the R5 to better photograph fast-moving birds in flight.The R5 seems to have RAW and HDR settings?If my goal is to track a fast-flying bird across the sky, do I want multiple HDR sho...
I have watched several youtube videos nothing has solved the problem, recently got a SD card for it and a new battery. It is still not turning on.
I have a Canon EOS R7 and i have 2 SD cards that when I’m trying to format them it says “cannot format” and one that has a “write protected”. Any recommendations on a fix??
I had my Canon EOS M200 for about 2 months now, and I'm seeing a white and colored spot on the LCD. This is only showing on live preview but not on the actual photo, JPG file, and menus. I just noticed this after a warning that my camera is overheati...
Hi please help.I have recorded video clips on my Canon EOS R50 camera with the settings at HDR PAQ.I am trying to upload these video clips via the Canon app to save to my iPhone but it says I need to change the file on the camera.I have no idea how t...
Hello everyone, just over a year ago I bought an EOS M200. For a while everything was fine until around Christmas time it started giving me, often and willingly, a problem. When I recorded for too long and then turned off the camera (for a lens chang...
Hello everyoneI wanted to import my photos from my EOS 350D to my mac. I tried to download the EOS Utility 3, but an error message appears upon connecting the camera through USB, saying that the camera is not recognized or that the communication via ...
Whenever you press „bin” button all settings revert to auto,shutter,aperture and iso. Shutter seems to be set to 1/60 which I would like to increase.
I run a computer repair business and a customer came in with his laptop and his camera, asking if I can do some maintenance on his laptop and if I can figure out why the camera stopped taking pictures. The laptop is obviously not going to be a proble...
Once I turn on my camera it starts taking photos on its own if I don’t have the lens cover on and LCD screen won’t show anything. I tried pressing the menu button but nothing shows up and also the memory card isn’t inside the camera.Plus once I remov...
Does anyone have similar issue as this video? I bought a refurbished R6 MK II and the quick control dial didn't feel right. It felt shabby and was making different clicking sound when in particular positions (when my thumb is on lower left side vs ri...
Canon R8 cannot read SD cards that it was reading just fine for weeks. It is a new camera, and I cannot detect any damage when I peek into the card slot. I am using cards that are listed as compatible on the Canon site. I also reset the camera to fac...
Hi- I have the R7. I used the iPhone app to download the update onto my memory card and followed the prompts to update the firmware (1.1.0 to 1.4.0), but it seems to be stalled and I can’t select “ok” to start the update. I’ve waited 15 min without O...
Hello,I currently own a Canon D80 with the following lens:Canon EF-S 18-135mm F/3.5-5.6Canon EF 70-300mm F/4-5.6Sigma 200-600mm F/5-6.3I would like a 2nd body that is comparable to my D80, but an upgrade even slight would be preferable. I shoot prim...
Subject | Author | Posted |
05-11-2024 07:46 AM | ||
05-10-2024 11:53 PM | ||
05-10-2024 09:22 PM | ||
05-10-2024 08:22 AM | ||
05-06-2024 10:23 PM |
