05-09-2024 08:03 PM - edited 05-09-2024 09:54 PM
Does anyone have similar issue as this video? I bought a refurbished R6 MK II and the quick control dial didn't feel right. It felt shabby and was making different clicking sound when in particular positions (when my thumb is on lower left side vs right side).
So I decided to return it and bought a new R6 MK II instead, and it has the same issue! Functionally it is working, but I just can't get it off my mind that this is some poorly built control and potentially a defect.
Does anyone else's R6 MK II have same issue?
I have a video of this issue which I couldn't directly post here
05-10-2024 12:37 AM
Thanks for clarifying your issue. TBO, on checking with R6II, it does sound slightly different on the bottom left compared to the other quadrants, but I have never had an issue with the operation of the camera and actually not really been aware until you brought it up!
05-09-2024 08:08 PM
Hi Zak:
My R6II has no such issues. Feels just like my R6 and R5 units, actually.
05-09-2024 09:34 PM
Thanks for confirming Trevor. My issue is that when my thumb is on lower left side of the circle the click sound is different than when it is on the right side.
I've gone to local electronics shop to test quick dial of other models and it definitely felt and sounded different.
05-10-2024 12:37 AM
05-09-2024 08:19 PM
It appears your R6 MK II is functioning correctly as @Tronhard (Trevor) pointed. I have a different camera (5D MK IV) and its quick control dial feels the same way. Yes it does make clicking sounds. So I do not believe your camera has a problem.
05-10-2024 10:46 AM
I had to check my R6m2 as soon as I saw this, and yes, I lightly hear the sound as well. It seems to have zero effect on anything though. So then I grabbed the 13 year old 60D... similar sound. Guess it's pretty normal.
05-10-2024 05:35 PM
The difference could simply be the angle of the pressure you are applying as you turn the wheel. It varies as you make a full rotation. What happens if you use your other left hand?
