PIXMA MX922 CD/DVD Printing Offset
My problem With the J tray for CD/DVD is when printing it prints offset , not center. I have used the Image garden alignment feature to try to adjust it, but still no luck. Anyone know the fix?
Hi, when printing on thicker stock only, I'm getting an ink splotch right on the trailing corner of the card stock every time.I've set the printer to the correct paper type and tried all the cleaning routines but it's still doing it. Any help?
Recently purchased the Canon Pixma MG 2522. I scanned some sheet music for work but when I print it out it has a white border. I want the image to fill the entire page without a border. I've been unable to.Also you can see the dull background. I woul...
Every time that I try to print a document as it's actual size the bottom and right ends of the document are but off by some margin features. I want the entire document to be printed as is and not with the Fit to Print Area Function on, I would like t...
Hi, so my printer can’t recognize the print head for black. I’ve tried the solutions on YouTube but did not work. Is my only option buying a new print head? If so what number should I buy? QY6 8026? DOES QY6 8021 or 20 work?
I am using a MacBookPro running Ventura 13.01 and I cannot figure out how to set the paper source between the cassette and the rear feed. The instructions say to go to the print driver but there is no way to access that on the Mac System Settings.Any...
My printer displays error code 495a. This is frustrating because when this error is displayed, the LCD menu system on the printer is disabled. None of the buttons do anything anymore, so I can't access the system menu to change wifi settings. The onl...
my mx492 gives me the 1688 out of ink error. the last cartridge was low but i'm sure was not out. i've put in a new cartridge but still get the error. as well, i can't scan. thnx
I know, I know, this thing is ancient and it's time for a new printer. But I'm an artist working on a weekly serial and I need to get this thing out. It will be a huge inconvenience to go to a kinkos or something right now because I just have too muc...
My Pixma 6821 uses the 270 / 271 series ink cartridges. I have error code 1413. The cartridge is a NEW Canon wider black ink cartridge.Is there another way to address this issue. Cartridges are expensive to have bought & then not be able to use! A te...
Hi, My canon mg5600 will not print in B&W as my colour ink cartridges are out... Even though I only need to print B&W documents and have no need for colour ink. The printer also has a scanner counter-part which is also not allowing me to scan docume...
I have a MX330. Works great otherwise but if I run out of colour ink or remove an ink cartridge it wont scan. I'm SCANNING. why does this affect scanning. It shouldn't.
I currently have a Canon MG5220 printer/scanner with an iMac operating with Mavericks. I would like to scan only with this unit, but I get an error message requiring me to replace the ink cartridges. Is there a way to bypass this error message withou...
I used to be able to scan without ink, but now I only get an error message to replace ink tank (U163). How can I work around this? Thank you.
i have pixma mp 270 series multi.function print. it can use without ink or cardrige for scan purpose
Subject | Author | Posted |
04-30-2024 12:14 AM | ||
04-29-2024 07:28 PM | ||
04-28-2024 12:33 PM | ||
04-27-2024 04:40 PM | ||
04-25-2024 07:00 PM |
