External Power T7?
Is it possible to utilize an external power bank to power the T7 through the USB port? Thank You!
One potential problem is I am on a Mac running Ventura (13.2). The Mac software on the support site does not show up if you pick Ventura as the OS on your computer. I have 3.16.1.3 and it seems to mostly work but I am having a lot of problems.I am ...
A grid can be displayed on the screen and viewfinder, but when you connect a monitor via HDMI the grids don't get passed to the monitor like the rest of the OSD info???
While shooting with my R3 in TV mode tonight, I somehow hit something and now the shutter speeds are like 1/1217.7 and I have no idea what I hit or how to take it off. Has anyone else experienced this?
Just setting up the HDMI output on my EOS M50. I thought everything was great upon initial appearance of the camera view on the monitor, then found that every 10-15 seconds the monitor goes dark for a few seconds, then the the camera image comes back...
I recently purchased a used Canon 60D with a 50mm lens for school. When she came home for Christmas we were unable to remove the lens. The camera is still functional. Is there a way to remove the lens and salvage the camera?
I’ve got a non-working 70D and a working 80D with some corrosion on the hot shoe mount. Are the hot shoe mounts of the two models compatible, and is it a simple enough job to remove and swap them out?
Hello friends, need your help. My M6 mark 1 suddenly got this issue stated in the title. I did not drop it nor did it got wet. Anyone experienced it and how did you fix? Thank you.
I have been able to connect my Canon R6 (firmware version 17) to my iPad Air (5th generation) RAW files after many hours. For now it is working well. Minor point - is it necessary to have to re-input the cameras Wifi hotspot under iPads settings ever...
I cannot seem to get the movie timelapse to work. It starts fine, but randomly stops after some number of images, and the movie is not saved. I can stop it manually (by pressing the exposure button) in the middle and it finishes and saves ok. I hav...
so i always shoot with AEB on. but every time i turn my camera back on, the AEB setting is gone. i have to keep remembering to set it up again. is there anyway to save its setting? or all settings of the camera?
On several occasions, my camera has become unresponsive: it is on, and the EVF is on, but it responds to one of the the buttons and menu. Pressing the shutter results in a click but no picture registering, and pressing the memory card button shows n...
I’ve been working with the T6i rebel for 7-8 years now and I’m looking to upgrade to something better for what I do. I shoot literally everything from cars to wildlife to straight portraits so I just wanna get something mirrorless and just overall be...
I've watched this entire video: Canon 7D Mark II Instructional Guide by QuickPro Camera Guides, and even though I got a lot of useful info, I couldn't make some of the functions work on my camera, such as the AF area selection lever. With the camera ...
Via both manual and auto setting of the HF Flicker Reduction setting of ex. 1/119.9, the shutter will reset to 1/128 every time after power cycling the camera. I only have 1 R6 Mkii body to test, but a friend just checked and his body does not have...
Subject | Author | Posted |
04-26-2024 10:18 PM | ||
04-26-2024 06:00 PM | ||
04-25-2024 12:42 PM | ||
04-15-2024 12:09 AM | ||
03-30-2024 12:16 AM |
