mx922 printer very slow and sometimes times out after printing half a page
Printer very slow. Sometimes times out after printing only half a page. Uninstalled and reinstalled the drivers etc. Still have the problem.
Attention Moderators:RESEARCH this issue within your own boards, and online. Apparently there's a magical "STOP PRINTING ANYTHING" date within this printer. here's a last ditch effort to see if anyone actually has a solid concrete fix besides what i...
I had to replace the wall my printer was plugged into. (plaster and lathe fell off so I had to replace with drywall.) Printer was unplugged and removed from the network for about a week while the damage to the room was repaired. When I plugged it bac...
Setup:Operating system: Windws 8.1Printer: Canon PIXMA 4520Connetion: WiFi on local area network.(Ask if you need more information.) I've had poor relations with this printer since I bought it a couple of years ago. But, I've managed to cajole it for...
I have a Pixma TR8520 and set up the fax portion and everything was fine for awhile but now when I get some calls I hear the fax beeping but I am not receiving any fax. This does not happen all the time only on certain calls. Yes, I have only 1 telep...
When printing photos the eage print fine but the center is blank. Please help.
My Canon TR4522 is printing very slowly. I am not sure why. I do have it running wirelessly and have since last year. I have not changed networks or printer location. It is sitting right by router and computer. I did change the black ink cartridge a ...
Hello all,As the title of my post says my mx920 just prints half of all pictures I'm trying to print.It scans and copys and prints text with no issue, I did all the maintenance on the printer installed new print cartridgesstill the same issue. Attach...
I bought a full ink cartridge of black ink and my printer doesn’t recognize it and it also has an orange light popping up next to a triangle I don’t know if that would help solve my issue.
I have a Canon Ivy printer, and it started printing with lines on it I'll insert an image: . How do I fix this?
What do I do about a PIXMA MG2120 Error Code E08?
I can't find drivers for ChromeOS on Canon's website. Is the PIXMA MG3120 compatible with ChromeOS?
Hi I have a Canon MG3000 series. When i turn it on the B and C lights are full on and not blinking. When i try to print it says the printer is in "error state" but no more details! al advice appreciated.thanks!
Printer has fault that I can't fix. Printing apprears to be fine on the first part of the page. Partway down the text then prints in white with black / grey tops to the letters so you can only just see it. I don't think it's an ink shortage because...
I refilled ink when the original ink level was very low. The refilling process was successfully After the refill, the printer still showed same low ink level, but still printed 1-2 pages.Now, the printer shows empty ink cartridge, and print only blan...
Subject | Author | Posted |
05-18-2024 12:39 PM | ||
05-18-2024 12:54 AM | ||
05-17-2024 10:43 AM | ||
05-16-2024 08:44 PM | ||
05-16-2024 12:18 PM |
