04-29-2024 10:49 AM - last edited on 04-30-2024 11:22 AM by Danny
I have a new K10392 and trying to match the ink cartridge model numbers required. I'm confused, don't know why - this should be easy. I don't have access to the printer to check the cartridge numbers. Thoughts?
04-30-2024 11:21 AM
Thanks for joining the conversation, hank5459! We typically identify printers by their model name which appears on the top or front of the printer, and that same naming is how we list printers across our web sites. We did a bit of digging and it sounds like you might have the PIXMA MG2522. In this case, the model number is on the top of the printer just above the power button. You can order inks for that printer right HERE.
If you have a different model, please let us know and we'll be glad to help!
04-29-2024 01:29 PM
That's not a Canon model number. It's something else. You need to identify the printer by its name.
04-29-2024 01:37 PM
04-29-2024 06:14 PM
@normadel no help. Anyone else?
04-29-2024 07:34 PM
Like i said, that's not the model NAME. The model of the printer is on the front or top of the printer. It's obvious if you're looking at the printer!
04-30-2024 11:21 AM
04-30-2024 11:24 AM
Thank you Danny for the info and your graciousness. I do not have access to the printer and the only ID provided was the picture above. Thanx. again.
