energy saver not available on MF4890dw
There is an error light on the printer, and, while it prints, it will not go into 'energy saver' mode. Can you advise? thanksLKC
I have a Canon Pixma ip90 and am looking for a battery for it. I've found a CK-51 for sale but am not sure if it is compatible...I fairly sure it is though. Am I right that the only difference between CK-51 and CK-51B is the colour (black)? Can anyon...
How can I fix my problem in printing head alignment? Column J always can't be printed. I use Canon Pixma IP1200. My computer OS is Windows 7. Thanks
Is it possible to use compatable inks on canon wireless printers
I am running an MG3250 with my PC which runs on Windows XP. I can scan single pages into PDF's fine but is there an option to be able to scan multiple pages into one PDF document?? Please help!
Hi! I have win 7 on my pc.Have installed MF Toolbox 4.9 and all the necessary drivers for the MF (Auto detect drivers).Printer is working fine, Fax I am not using since i dont have a phone line. My problem is that when i try to print through the mach...
My model 4920 printer has error c000
I can't get the MF Tool box to acquire the scanner function. "A supported scanner is not installed." I want to be able to start scans from my PC so that I can see/choose where they are being saved. Can canon software keep track of all scanned docum...
Can't figure out how to turn off double sided scanning on a Canon 7270. I would like to turn it off by default.
I would like to know if anyone has had experience using a Canon printer (MX series) with a U.S. electrical plug overseas with a 220v 60 cycles receptacle. The rating on the printer says: 110-240v, 50-60Hz and .94A. Thank you in advance for sharing yo...
I keep getting the message 'Ink absorber almost full'. How do I put this problem right? Many thanks Jack
Hi,my scanner is a Canon CanoScan Lide 100; it was previously installed on a Windows XP SP3 32 bit, driver was lide100win1403ea24.exe, and I could access the scanner through the native interface of the driver, rich of options and parameters to be set...
I just purchased an ink refill kit for HP Photosmart C410, using the HP 564 cartridge. The printer is giving me problems and I am inclined to purchase a Canon inkjet printer. Can I use this ink in a Canon product?
Subject | Author | Posted |
05-15-2024 09:04 PM | ||
05-15-2024 08:14 PM | ||
05-15-2024 06:38 PM | ||
05-15-2024 05:07 PM | ||
05-15-2024 02:55 PM |
