Resolved! networking question MG8120
I have 2 wireless networks in my home. Can the Pixma MG8120 connect to more than one wireless network?
I have continually expereinced difficulty with having this printer staying connected and then getting it reconnected to my wireless network. Cannon is not help. Any ideas.
Just had my net provider move me up to a 5g network... but since the printer wont connect is it 5G compatible?
Can a CISS be added to a MG2922?
Cannot communicate with scanner for these reasons:- Scanner is turned off.- (If using Wired LAN connection) It is disconnected from Wired LAN.- (If using wireless LAN connection) Signal strength is poor due to obstructions.- Network connection is pro...
MX472 will not connect to my Wi-Fi it was connected and then it dropped. I tried USB re-connection to wi-fi and it finds my network but says it can’t connect. This is the 2nd time in 2 months that this happened.
Just got a Canon PIXMA MX432 and trying to set up. It asks for me to push the WPS button, but can't find? Hep?
When I try to get a wifi connedtion with my Pixma MG5420 printer It is initially found, then not found, and I get error code 02125 0036. Then the setup starts all over again. Help!
I've been using my MX340 for some time, and love it. Recently changed internet providers from AT&T to Fidelity, so I have a new modem. In the past I've had several different AT&T modems, and each time I'd let the MX340 detect the network name, and wh...
I had to unhook the printer to get a paper jam removed. When I hooked it back up, I got the "press the WPS button for 5 seconds....." message. There is no button of any sort on my router, so let's not get on that ribbon. This is a wireless printer bu...
Hi: Our Pixma MP620 printer/scnanner was working just fine until we had to change routers. Ever since then it doesn't work anymore: the print/scan instruction goes out but then the system gets stuck. I gather the problem is that the Pixma does not...
I'm sure this has been addressed earlier, but I can't seem to find it. I have a friend with a Pixma MX922 which I understand only connects at 2.4g. She cannot print or scan when she is connected to her router at 5g. She keeps having to switch her lap...
I bought this printer over a year ago and had it connected. I then moved and just unpacked the printer. When I try to print, I initially could see the printer but it said "not connected." I have deleted the printer from the list of printers but n...
i have just purchased the above new printer but my router does not have a WPS button neither does my "Notebook" have a CD driver so how to i connect the printer please. i also have an ipad but this does not have a cd driver either of course
Where can I locate the WPS Pin when trying to connect my MX492 to Windows 10? I just purchased a MX492. I am attempting to connect wireless to my PC with Windows 10. My Windows printer setup is asking for a WPS Pin "located on your printer or with i...
Subject | Author | Posted |
04-24-2024 10:59 AM | ||
04-24-2024 07:00 AM | ||
04-23-2024 02:15 PM | ||
04-21-2024 12:01 AM | ||
04-19-2024 11:39 AM |
