When I need the pop up flash on my EOS 7D, I get an "err 05" message. ???
The camera doesn't flash and no photo is taken. It tries to open the flash but it won't release.
none
I'm wondering if anyone is having the following problem. I'm having a pause problem with both my 5D III and 7D cameras. I’m shooting raw on a Lexar Pro 1066x card in Al Servo High Speed mode. When I'm shooting a sport like soccer, basketball or footb...
The Canon 7DMkII uses a LP-E6N battery; the 5DMkII uses a LP-E6 battery. It appears that the battery chargers are identical. Can I use these batteries for both cameras?
I have an EOS Rebel T5 that I got last summer to record videos on- as well as take photos. I also have a 16gb and 8gb SD card to go with it. I have a problem where (on an epty SD card) I will be filming a video and it shuts off after about 11 minutes...
I realize that Canon will not service a gray market camera under warranty but will service and repair such a camera as if it were out of warranty? That is, for money like any service shop? I have never needed Canon warantee service because nothing ha...
I am trying to get the lens direction data from the EXIF file - when I was shooting I could see both direction - NE and the degrees 45 - however the GPS data in the metadata only shows the lens direction not the degrees - so I only get North East or ...
I have connected my T6i camera to my PC with the provided cord but the camera does not show up on the PC.I am running Windows 10 with camera firmware version 1.0.0 (I don't know if there is a newer firmware version) Device manager does not show any i...
Uploaded 10 images one hour earlier with no problems, now this blinking message. What does it mean and how to correct.Also get the number 592 next to the blinking bu 59. Canon EOS D 50 / computer is iMac 2015 with latest version Yosemite. ...
Edit: After lots of reading I see that I am past the point that the 1.0.6 firmware update would have solved. Is there any way to flash the camera if it is non-responsive to the computer? What are my options? _________________________________________...
I have opened up LR5 and told it that I was starting teathered capture. Prior to that I plugged the cable that come with the 5DM3 into the USB port. All the while LR5 says on Camera detected, but it is plugged in, one and have depressed the focus b...
I have a Canon T5.Today I tried to copy images over to my pc. I may have changed to Windows 10 since the last time I did photos. Anyway, when I try to copy the pictures..it says "Waiting....Canon EOS Rebel T5 is busy" Any advice appreciated! Cheryl
I had a strange thing happen this morning while doing sunrise pictures. I set my camera up as always shutter, aperture, iso but I notice that when I changed the shutter speed that the aperture was adjust by itself? I dont recall this happening before...
Occasionally when I take photos they appear with vertical gray lines through them. This lasts for a few photos then goes away. When I am recording a video the gray lines appear and then often times disapear later in the recording. When the lines a...
My computer using Windows 8 doesn't recognize my Canon Rebel. How do I fix this?
Subject | Author | Posted |
04-28-2024 09:09 AM | ||
04-28-2024 06:01 AM | ||
04-27-2024 08:20 PM | ||
04-26-2024 06:00 PM | ||
04-25-2024 12:42 PM |
