08-03-2017 11:29 AM
I just started using the 5D Mark IV. It processes too slowly, giving me a BUSY message, taking more than 3 sec. to process! I also can not shoot in bursts. Am I missing a setting that does not allow me to process quickly? My 5Ds is amazinginly fast and I can easily shoot in bursts. What I am doing wrong?
08-03-2017 02:36 PM
08-03-2017 12:31 PM
Is DLO on?
08-03-2017 02:17 PM
08-03-2017 02:36 PM
08-04-2017 09:00 AM
Thank you! That was the problem! I always make lense corrections in DPP, but didn't realize it the Mk4's default settings left the DLO on...works perfectly now!
02-20-2021 11:17 AM
Hi, i have a query.
I have disabled DLO and Dual Pixel RAW, but i get only 12 images to click with high speed continuous mode while shooting birds or wildlife.
Is there any way that this count can be increased?
i also upgraded my memory card to 300mbps write speed.
Kindly help me on this.
02-20-2021 02:05 PM
What are you shooting, that sounds about right for RAW+JPEG.
Otherwise, do you have an aggressive noise reduction on?
02-20-2021 02:28 PM
@raghuviju wrote:Hi, i have a query.
Does it totally stop at 12 or does it just pause a few frames then do 12 more?
08-03-2017 11:25 PM
@RobinS1 wrote:
Sorry, what is DLO?
Digital Lens Optimizer.
If you shoot in RAW, you don't need it, because you can apply it in post-processing.
And the only compelling reason that I've found to shoot JPEG is to get the picture to a newspaper in a hurry. Believe me when I tell you that photo reproduction in newspapers isn't nearly good enough to have it make a particle of difference whether DLO is used.
08-04-2017 09:01 AM
Thank you so much...this was the fix I needed! I appreciate your help!
