paper jam tr4522
paper is jammed in the rollers in the back of the printer, not at the intake area. it's crunched up
I turned on my printer, and after its routine wakeup, the LCD display tells me a printer error occurred: "Support Code 6000." I followed the instructions: canceling any printing, turning it off, unplugging it, replugging it, and turning it on again. ...
Pixma MX922 has two black cartridges, one's big and the other is the size of the color cartridges ? When one gets low, then I have to replace it, it doesn't "switch" to use the other one which has plenty of ink. Why is that ? What's the point of havi...
I have a Pixma G7000 series printer (G7065) that has suffered at the hands of an unqualified "serviceman'. As a result two pieces associated with print head cleaning became detached. I have reattached one of them, the wiper blade arm, but I am unsure...
Hi guys,I'm sure this is user error, but my printer will not copy the bottom 1" or so of any document I place on the glass using the black or copy buttons. It seems to print fine when opening the doc on the pc and printing, it's just the manual copy ...
To: Community :Re: TS 6420 Does this Printer ...PRINT. in Color or ? It only prints B-W No INSTRUCTION MANUAL. as per Usual these Days !10-4
New poster here. I know this problem is an old one for most of you, but my printer is just now stuck in the reboot loop. It won't stop long enough for me to update the firmware. I have tried everything I can think of, any suggestions? I need this fo...
Help:I bought subject printer/scanner back around 2010 and never had a problem with it. All of a sudden the scanner wont work...error code5,202,54. I tried the online fix but they didnt work. I still have the setup disc from years ago. I am running W...
Canon Pixma MX490 powers on and goes through initialization, then powers back off. Keeps repeating the process as long as it's plugged in. Buttons are non-responsive.
I got the new M1 macbook pro that is running macOS 11.0 Big Sur. I tried to find the drivers for my cannon MX340 printer on the cannon website for this operating system, but none are listed. Am I missing something, or is this printer not yet suppor...
I am thinking about buying a canon prixma tr4720 for both me and my father. My father wants to be able to send faxes to me and others. The tr4720 has a built-in fax capability but neither my father nor I have a land line phone. Can the tr4720 send an...
What is the front USB port for on this printer?
Where do I find the model # and / or serial # on an older Canon PIXMA printer?On the bottom I found: Multifunction Printer K10356There is a barcode: 34517 in another area.I need the driver for my new computer.
I have noted that my printer is printing blurred and shadowed characters, but only from the PGBK colour. I have replaced the cartridge (all original) and performed all cleaning procedures, but the problem persists. Any thoughts?
Subject | Author | Posted |
04-30-2024 03:44 PM | ||
04-30-2024 02:28 PM | ||
04-30-2024 08:57 AM | ||
04-30-2024 12:14 AM | ||
04-28-2024 12:33 PM |
