02-08-2022 02:03 PM
I don't even get the option to set the paper size to legal.
02-08-2022 08:02 PM
You didn't specify, but did you upgrade your printer software when you upgraded to W11?
02-09-2022 05:31 PM
Hello Briggman,
If you have upgraded the computer to Windows 11, you can remove any old connections for the printer and then you can try reinstalling the UFR printer driver.
You can press the Windows key and the letter R key at the same time on your keyboard. In the run box that appears, you can type in control printers and click OK. In the Window that comes up, you can right click on any connections for the printer and then select remove device.
Once all the connections are gone, you can download and install the recommended driver found in the link HERE. Once the driver has been reinstalled, you can try printing again to see if you have the correct paper sizes in the print window.
