Control 600EX-RT using 70D
Hi. Since Speedlite 600EX-RT wireless use 2.4Ghz frequency and 70D has wireles built-in (which works on 2.4Ghz too), is possible to trigger 600EX-RT using only 70D? No the light way, but radio way. Tks
telephoto. Is there a market for these and do the lenses work on current digital Canon cameras?
When I mounted my Kenko Pro 300 1.4x teleconverter to my Canon 500 F4 IS I lens I got no focus at all. The lcd is frozen, no shutter release or auto focus! I then reset all in camera settings I made and then powered off and repowered and then it wor...
Hello Team, I have a Canon 4Ti, currently running the current 1.0.4 Firmware. the issue is that the screen has scattered, multi colured, distorted lines while using it in live mode. these lines appear when i power on the camera and could see them on ...
I just purchased a 6D, 600EXT Speedlight, 16-35 f2.8l, 24-70 2.8l and 70-200 2.8l. Can someone please recommend an appropriate camera bag for my equipment? I'm leaning towards a messenger style shoulder bag. I want it to be inconspicuous, weather res...
Videos created are not viewable on the camera and when uploaded to my computer the files are not playable"Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress t...
Im looking for a inexpensive TV/Cin lens to use with my Canon T3i for shooting video. I have found a Tokina TV Lens 12.5 - 75mm f/1.2 C - mount and was wondering if I can use it on my T3i. I have used other lens on my camera with adapters and or ext...
Hi! I'm new to the group. Just was wondering if any of you have tested the new Rebel T6i? Thoughts?
I have the original EOS DSLR that came out in 2004. It's working ok, just slowing down. I want to buy a new Canon and was wondering if the original lens, the 18 to 55, would fit a newer camera. I also have a Tamron zoom lens I got back in 2006 or ...
I just bought a brand new sandisk 'extreme pro' 32g card, and set the camera on a windowsill trying to record a jar. It still stopped recording after a few seconds. It has done this with the last three cards I've tried in it. This is pretty much a b...
When a large area of sky is in a photograph, I see what appear to be waterspots in the area, but the glass is clean. Is this a sensor problem? It happened with my previous Canon DSLR as well. I use the 100-400L lens on a 60D. Thanks.
I need any related downloads for my pc (windows 7 64bit) so .. My canon rebelxt was a gift and they don't have any disc's that came with it.
the camera does NOT work if the memory card door is not on it. i can put the two pieces together and close the door up still and the camera will work, but it will not turn on if the memory card door's two pieces are not together and the door closed. ...
My 8 month old Eos 70D has decided "Card Cannot Be Accessed". The only suggestion I can find for a solution is to format the card in the camera, but I cannot do this because of the error. I suppose it will be a warranty repair but it is concerning ...
Hi everyone! I've been using a t3i for the past four years and want to upgrade but not sure what to get. I love macro and I want to get into more bird/nature photography. I'm thinking of getting the telephoto lens 400mm 5.8. Any suggestions as to whi...
Subject | Author | Posted |
04-28-2024 01:45 AM | ||
04-27-2024 08:20 PM | ||
04-26-2024 06:00 PM | ||
04-25-2024 12:42 PM | ||
04-15-2024 12:09 AM |
