05-16-2024 03:56 AM
I got two EOS 1V and unfortunately the shutters have gone bad on me. Given this is a discontinued camera. Does Any one know where I can get this serviced properly?
Thank you for the help.
05-16-2024 08:58 AM
Where are you located?
05-16-2024 10:46 AM
Michigan
05-16-2024 11:23 AM
camera repair shops in Michigan
This search in Safari brought a number of hits. Maybe another forum member has experience in that part of the country.
05-16-2024 11:27 AM
I searched all over Google and called. No one In Business has experience or wants to take this model of canon
05-16-2024 11:29 AM
Try Keh Camera in Atlanta and Hunt Photo in Melrose Massachusetts.
05-16-2024 11:30 AM
Where to get it serviced or repaired isn't the problem getting the replacement shutter just might be however. You may be in a mail order situation for the repair and may only be able to get a used shutter assembly. After all that is a 25 year old camera and I suspect around $500 bucks to do it.
05-16-2024 12:33 PM
With shutter failure, these are likely both high use bodies. What does the film roll count show for lifetime usage?
If you want to stay with this style film body, I would seriously consider looking at ebay where they have a number of 1V bodies with low roll usage counts which would probably be a much better deal than replacing just the shutter assembly on a high usage camera body.
Rodger
05-16-2024 03:44 PM
First one was 600 rolls and 2nd was only 96 rolls.
05-16-2024 03:45 PM
My 2nd canon 1v so f as this only doing this. But I suspect this thing over exposed line is just a prelude to blade failure
