EOS. 5d mk2 frozen
DCS1
Hi all
Was taking fairly low light shot and after pressing shutter release camera froze. - no displays and red light on rear continually flashing.
Have tried removing battery, card, lens. Leaving camera off for a whole. Turning camera on without battery and holding down shutter release none of which work. On reinserted battery and closing door just flashing light on back.
Anyone have a solution?
Thanks
1 REPLY 1
Hazel_T
Hi DCS1,
I'm sorry to hear your camera is frozen on. Looking at your message you already tried some of the things we would recommend. I do not see a mention on if you tried loading a different battery, memory card, or attaching a different lens on the camera. Sometimes if one of those pieces is malfunctioning it can cause freezing and power issues.
If the issue continues normally we would recommend sending the camera in for repair. Unfortunately the EOS 5D Mark II is out of service life, so repair options are no longer available for it. In that case the only option available through Canon for that camera model would be the Canon Upgrade Program.
Through the Canon Upgrade Program we would be able to generate a 10% discount code you could use to purchase replacement equipment. If you want use the Canon Upgrade Program you will need to call our sales team at 1-800-385-2155 from 9 a.m. to 9 p.m. Eastern time Monday through Saturday. They will also be able to assist you if you have questions about buying products, when products will be back in stock, and what products the discount code can be used on.
Enter for a chance to win!
April 20th-28th
