Canon TS9020 Ink on Parts
I have a Canon TS 9020 that appears to have a lot of ink covering parts on the right side of the ink pump; is this normal or should I attempt to clean it.
I have a canon MX532 printer. It has been great. Recently, it has stopped printing complete documents - the furthest it will get is 50% through the document before it stops printing. The printer settings show the printer is "busy" and then it gets...
Hi all,I am trying to install a Pixma MG2524, and when I try to complete the installation I reach the 'Printer Head Allignment Completion' screen, and then the installation consistently times out- after about 10 minutes it starts to say 'printer not ...
I scan with my Canon inject/ selphy some docment in .pdf. and download them. But where can i find them back on my Opo phone, or my ipad?
Canon PIXMA MG3520 not compatible with macOS X Ventura V13.0I too am wondering when Canon is going to issue a compatible software update? I had to do a laptop refresh for work, and I've wasted so much time trying to figure out how to get it to work, ...
I have an HP Pavilion and was recently forced to change to Windows 11. My always dependable PIXMA MG 3520 refuses to print or scan, and the Canon website does not show a Windows 11 driver. A friend who works in IT tried for 2 hours to install a dri...
Hi! My Pixma MG5420 is not printing cyan. I had a friends son come by and run the clean twice and deep clean option as well. When we printed the test sheet blue was not printing in all instances.He checked the ink cartridge and it was installed pr...
Can pixma Mg3000 print on vinyl sticker paper
So as the title says, the black ink cartridge doesn't seem to be making a complete connection with the carriage. This only happened when I tried to replace the Magenta and Yellow cartridges. If I put the old empty Magenta and Yellow cartridges back i...
Hi I have an IMac and I own a canon g6020 and it’s extremely annoying and frustrating and irritating that Mac does not have a driver for this printer. Is canon going to develop a driver for this printer yes or no? AirPrint is the only option and it’s...
Hi all,I am trying to troubleshoot my mothers printer. We just replaced both ink cartridges.Now, the printer beeps every 2 seconds or so. The printheads move all the way over to the right and tries to go back to the left but stops and returns to th...
Hello!I have tried cleaning my MG6620 multiple times. It has new ink. I've even looked up others with the same problem and have cleaned the encoder/timing strip 3 times (with isopropyl alcohol 2 times, windex 1 time), and also gone through all of the...
my canon g4210 printer has stopped printing on paper. Paper comes thru with no print. what might be wrong and how do i fix it
PIXMA922 printed a blank page for me then shut down. It would not power on again. Tried the unplugging, waiting, and re-plugging into a different outlet. No good. I am unable to try any other "fix-it" methods with no power to the unit. At one point, ...
Printer had been working fine. Then, when I turned it on yesterday to print something, it ran into a problem. I pushed "Print" and it started to print and then the paper jammed about 1/3 of the way down. I pulled the paper out of the machine and note...
Subject | Author | Posted |
04-28-2024 12:33 PM | ||
04-27-2024 04:40 PM | ||
04-25-2024 07:00 PM | ||
04-25-2024 03:03 PM | ||
04-25-2024 05:02 AM |
