04-03-2015 07:19 PM
04-03-2015 07:23 PM
04-04-2015 08:45 AM
See this article. http://www.outbackphoto.com/printinginsights/pi049/essay.html
Before you start adjusting set the monitor contrast and brightness to midpoint of adjustment range. Most monitors are set too bright.
04-04-2015 05:15 PM
04-08-2015 10:42 AM
You can not set the printer to match the monitor. You must set the monitor to match the printer.
First, you must not let the printer set anything. Turn off every bit off control it has. You can do this with the Canon My Printer under the Printer Settings tab. Do you know how? I will guess, yes, for now but if you don't get back to me.
Second, you need to have your photo editor (like Photoshop) handle all the print settings and color matching. You know how to do this? I prefer Photoshop and I use AdobeRGB color space.
And lastly, it is essential you get some settings on your monitor that somewhat matches what the printer is printing. Your printer may be doing exactly what you are telling it to do and you have no idea it is, because your monitor is so far off. If you don't do this step, you can forget the other steps. However, there are only a few things that you need to be concerned with. You don't need any fancy extra add-on to do this. No additional software or gadgets, etc. No monkeys, no spiders, nothing!
Most people set their monitors too bright.
You must get the gray-scale very close. You need to get the brightness very close and you need the contrast very close.
After you do these things you can make adjustments to your prints by just looking at your screen. Because you know the monitor and printer are on the same level. One more point, you can NOT get a printer to print every color exactly the way you see it. It isn't possible as all colors and adjustments effect all others. My goal is to get the skin tones right. That is what people notice most. Remember you are dealing with two different disciplines here. One is colored light and the other is colored dyes. They are not the same thing.
For instance, I know my Pro-100 tends to print slightly darker than what I see on the monitor (typical). So, I automatically know to set it's prints 1/2 to one stop brighter in Photoshop, in my case. It also prints with a slightly warn tone. Most of the time, with portraits especially, this if OK but sometimes it is not. In that case I adjust the "temp" setting slightly cooler in PS.
All the Canon photo printers I have ever seen have this warm/magenta cast. Canon engineers must prefer this look. It can not be changed. You need to "fix" it in post.
Make sure you have the correct ICC profiles and you are using Canon brand ink and paper until you get good with the printer. Very, very important, otherwise you don't know if the printer is doing exactly what you are telling it to or not.
Important is, use the USB connection until everything is right. You are just adding another issue when you try to set up the printing and the wireless all at the same time. Just like using Canon branded products until it is a go. Use a real printer USB cable. Not just any old USB cable. Get everything right before you explore.
04-08-2015 06:45 PM
The previous advice to set your monitor to match your printer is quite correct if:
The reason for calibrating your monitor is to make your prints adhere to some standard so your images will look or print the same everywhere.
04-09-2015 09:52 AM
Nonsense!
The Canon Pixma Pro series comes with pretty standard print settings and ICC profiles. It is far easier for the majority of users to adjust their monitors to match it.
I use WHCC and Shuttterfly and some other pro houses and have no issues. I use Flickr and Google+, too.
Plus it doesn't cost a thing extra.
04-09-2015 10:03 AM
So your monitor is the same as the standard?
It must be close since your pictures on Flickr look OK.
that's what I'm saying, calibrate one's monitor to the standard.
01-17-2016 12:38 PM
This ia an old thread so I'm hoping someone can still respond.
My monitor is properly calibrated - prints turn out spot on from a pro lab and from my Epson printer. However, on my (new) Pro 100 printer, the colors are off (toward the pink side) and darker. As I said, the same Photoshop file prints correctly at my pro lab and on my Epson.
I even downloaded Bill Atkinson's test print - it prints properly on the Epson but clearly shows the shift toward pink and green in the skin tones and the sky toward cyan.
The only difference is the test image is in ProPhoto RGB and my image is in sRGB.
This is a bit frustrating at this point.
01-17-2016 12:55 PM
If you go into the printer driver you can dial in adjustments. See your On-Screen manual.
