mg3650s remote connection
hiif i connected my printer with wps to the internet can i connect to it remotely from another network?
Over the holidays I "upgraded" from a Windows 10 computer to a new Windows 11 computer. I loaded the latest Canon printer drivers from the Canon website, but now all the "black" in my photos is printed as purple (when I am printing in Photo mode). I...
Hello,Is there a way to apply auto crop of scanned documents for IJ Scan Utility on Mac Sonoma to have scanned documents without white borders?Thanks
I changed my room and now all of a sudden my printer does not connect with my pc, laptop nor mobile phone. I tried everything and made sure that i am on the same router, but still no connection between the devices.
Hello,I have a Canon LBP6030w. I have all the software installed and was able to connect the printer to my home wifi. When I hold down the grey button on the printer it prints the wireless connection summary with the IP address and all that. It says ...
I recently installed a new MF656CDW. It is working fine on the network and I can print to it fine. I can also access the remoteUI. When I tried to update the firmware over the internet it first shows the message "Checking firmware version" for abou...
I tried to update PPL from 1.3.6 to 1.3.8, but when the installer starts installing, it very quickly halts and outputs this error message:Not a helpful message.The only thing that seems to have been done is to remove PPL ver 1.3.6Tried a few times, n...
I purchased my Pro-100 new. Other than the usual problems trying to get accurate color it is worked fine. Recently I had to replace my PC with one running Win10 64 bit. Can't get acceptable color. Did all the usual checks- inks are fu8ll, nozzles not...
PIXMAG3200 prints to upper left corner. Using Sonoma 14.1.2. Any fixes to this? Just downloaded RECOMMENDEDFile NameG3000 series CUPS Printer Driver Ver.16.80.0.0 (Mac)TypeDriversDate11.05.23File Size15.91 MB
Hi!So, I'm facing the 100. problem with this printer since I owning it. Now I would like to print a pure black and white picture, but the printer wants to print it using colored ink at all cost. There is not a single pixel which is coloured. And if I...
my computer will not accept the drivers that you have available because they are not Microsoft verfified.need help
Hi. I have a Pixma Pro-1 and an Imageprograf pro-1000 (two different locations, two different computers), and use print studio pro with photoshop to print on both. When I try to print, I cannot get either machine to print out at the correct size, and...
Hello.Windows 10 OS.I just upgraded my WiFi service with Frontier from 500mb to 1gb, together with a new eero router PRO 6E and 6+ extenders. I've read and tried setting my network to 2.4 GHz -to test- and did not work either. I am currently connec...
imageCLASS MF656cdwWhen scanning a document into a pdf file, the file is created, but when specifying to open it with the Canon IJ scan utility, I get an error message that it can only open PDF files. It is a PDF file. I close the IJ scan utility, ...
The software I use needs a TWAIN scanner. MF269dw scans with its' utility but it would be great to be able to scan directly into the software I use. Is there such a thing as TWAIN driver for MF260 series multifunction machines? I did not find it o...
Subject | Author | Posted |
06-01-2024 06:27 AM | ||
05-29-2024 04:41 PM | ||
05-28-2024 09:03 PM | ||
05-28-2024 07:17 PM | ||
05-21-2024 09:22 PM |
