05-12-2013 08:07 PM - last edited on 12-02-2022 08:48 AM by Danny
Out of nowhere, I came up with a memory card error on my canon power shot sx 200 is. Any suggestions on how to correct the problem?
09-17-2013 08:43 PM
The best (most dependable, error free) Memory cards are Sandisk brand.. Off the wall brands are iffy at best. Recommonded are name brand cards.
01-25-2017 06:33 AM
I use Sandisc & they pack up every 2 months or so. CAnnot rely on my camera when away from home
10-05-2015 07:41 PM
1. Older Canons (pre-2007) can only use SD cards, not SDHC cards.
2. There is a tiny tab on the left side of the SD card (when you are reading the front, tab is on left side). Slide it up to lock the SD card, and slide it down to unlock it (when you want to use the camera).
3. Remember to format the SD card. See your owner's manual or look on-line to get directions.
If these things don't solve your problem, you may have damaged the SD slot reader. You may have to have them repaired.
02-14-2016 07:49 PM
I have an S2SI canon power shot, I put a new memory card in it and it wont read it. It says there is a memory card error. I checked to make sure the tab on the card was in the right position. I went to the tools in menu but the space for "format" is dark and I am unable to click on it? I am very frustrated with the whole thing. I hope someone can help! Thanks in advance!
02-16-2016 04:41 PM
Hi Roxyrocket,
So we may better assist you, please reply with the following information:
02-16-2016 07:38 PM
I tried the 16 GB SDHC (SanDisk) I then tried a Toshiba 16GB SD only memory card.
02-18-2016 03:37 PM
02-18-2016 10:54 PM - edited 11-24-2016 10:52 PM
@Richard wrote:Hi Roxyrocket,
- Does this occur with all memory cards that you've tried?
- Which memory card model(s) are you using?
Ask your QA team to test your product selling it.
Same issue: http://community.usa.canon.com/t5/PowerShot/Canon-a-worst-product-and-service/td-p/164543
02-20-2016 01:04 PM
02-20-2016 01:47 PM
Have you tried them in a computer or another device yet?
