...As the title says, the MFA software by Reikan has today released an update allowing microfocus adjustment on the 7D2. To get it log into your account on their site....if you don't have it, I'd recommend it, it isn't cheap but it takes the guesswor...
I will be upgrading soon from an XTi to either a T5i or SL1. I dont have the original lens for the XTi and I dont plan to use the STM lens that the new camera comes with. I was going to give my old camera to a friend by putting the kit lens on it. Wi...
have rebel xt purchaced 7/2007 works great but upgraded my computor to windows 7 will not download computor teck said need change something on menu on camera. he did it and it worked but didnt say what did because it back same not downloading
dropped my canon rebel t4i camera,broke off canon symbol just under flash hard plastic piece.Is there anyway to fix this???
Is anyone else having this issue? Since updating firmware on my 5D the ISO button has varying levels of stickiness. Meaning when I press it and move the dial it drops out of ISO mode, sometimes immediately, sometimes after a second, and yet other tim...
What indication is there to confirm that the 7D Mii has achieved focus when in AI Servo mode with point expansion or single Focus point selection?
iMac with Mavericks won't recognize new 60D
If I activate the shooting function screen by pushing the INFO button and then take a picture the LCD screen will showthe shooting settings for the picture just taken. It seems like the information is displayed for at least 20-30 seconds before the s...
I have a Client that needs a short Video of her Visual Performance Prop, shot with a matched Shutter Speed and Frame Rate to properly capture it. Ideally (according to the Manual) I should be able to match the FPS (30 fps) with Shutter Speed (1/30) t...
Hi, I've tried to connect via the supplied cable my 7D2 to my MacBookPro. I have a 2009 13' MBP with USB2 ports. My softwares for use with the 7D2 are up to date (EOS utility, Lightroom). I shoot tethered all the time with my 5D3 on that computer u...
Assuming proper lens is used and setup the same on each camera ._t5i t4i t3i t2i Best choice ._.For birding/wildlife ? For 7 yr old twins in motion? Thank you for your knowledge and wisdom .
I get a reading that says can't get ISO 100 because Highlight Tone Priority is enabled - Auto D+. The only way I can access Highlight Tone Priority is with video setting, I change to disable, hit set then go back to ISO but it still gives me the sam...
Hello I am looking to buy a DSLR and am sort ofon a budget my question is what takes better pictures the 1200d or the 100d thanks
Currently, It will only allow me to film clips 10-15 seconds... how do I change it to allow me to film longer??Thank you!
Subject | Author | Posted |
04-28-2024 09:09 AM | ||
04-28-2024 06:01 AM | ||
04-27-2024 08:20 PM | ||
04-26-2024 06:00 PM | ||
04-25-2024 12:42 PM |
