EOS 5D Mark II Black shadow on each image
Can you tell me what’s wrong with my camera ?The bottom is dark, when I turn it vertical also black bottom yesterday was working nice, shots 29000
Hi! I'm having the same problem with my Canon EOS M50 Mark II! I have had the camera for 1 year and 8 months as a hobby. I got a Sigma lens 1 year ago. When I used it today to shoot flowers close up, it suddenly turned itself off after working fine. ...
I want to reset my EOS R. The number 6 for reset is not under the settings tool
Every time I take a shot, the picture will flash for a second or so but the LCD screen then goes to the level indicator (which normally does not appear unless I toggled the INFO button). I can't seem to get it to stop doing this. Any suggestions?
I was just curious.If I take a 30 second exposure, and an exposure of 1/200th's of a second, is the 30 second exposure a larger file size; i.e. more bytes?Steve Thomas
I intend to rent an EOS R5. I will be using both the CFExpress and SD card to record video in RAW and 4k MP4. The rental package comes with a 64 gb CFExpress card. I will be saving to a 256gb thumb drive via macbook pro running ventura and canon uti...
My flash is not working. The external flash pops out but the option to use flash isn’t available.
HI,I cannot connect my R8 to the wiFi: error message Err64.Do you know why?Best
i am about to rent the canon EOS r5 to shoot video. I intend to shoot raw for future use by more qualified people and also shooting in MP4 for immediate editing and use on websites. I would like to use my macbook pro with ventura OS, 2.3 ghz dual cor...
Hello,Will the Speedlite 470EX-AI work on the Canon EOS R7? I know it says EX will, but just wanted to make sure.
I've been trying to figure out if there is a way to set one of the physical buttons to function as a digital zoom while shooting. I shoot with a manual 50mm lens on occasion and being able to focus peak without using the touchscreen would be incredib...
Hello, im a Real Estate photographer. I bought an external monitor specifically the Feelworld lut 6. All works 100% correctly on my Eos R but the electronic level does not show. I have tried all the possible configurations without any results. I know...
Hello, I'm currently facing difficulties uploading my photos to the computer via Bluetooth. Consequently, I'm considering purchasing a cable to connect my Canon M6 (2017), but I'm having trouble identifying the correct one. Despite ordering several c...
I just visited a pawnshop here in central Oregon found a 5D MK II with 17-40mm L and 70-300 USM 4-5.6 and a 430ex II in an Ape Bag and I took some pics with it and they looked really good. Paid 450.00 wanted to make sure it was not going to die on me...
I am sure this must have been discussed before.I have had my Mk3 from new around 2009 and it has not had much use and is still in mint unmarked condition.However after about 3 shots the mirror stays up and i have to switch it off for it to go back do...
Subject | Author | Posted |
05-16-2024 03:56 AM | ||
05-14-2024 11:01 AM | ||
05-12-2024 09:21 PM | ||
05-11-2024 10:35 PM | ||
05-10-2024 09:22 PM |
