Resolved! Need Manufacture Date for EOS Rebel T5
Here is my camera serial number: 232074[XXXXXX].How can I determine the date of manufacture?[Serial number partially hidden for privacy.]
Hi, so I accidentally hit a button on my canon EOS R3 and now I have this random flashing gray box on my screen/viewfinder. I know it has to do with auto focus as when I focus on something it disappears and when I’m in manual focus it disappears as...
Hello....so i am using canon 70d and i have been facing a problem and would like some helpThe problem is that when i am changing the modes i'm not able to see the modes on my camera its just dark when i change the modes so anyone can help me out.It w...
Hey guys my camera won't turn on and I don't know what seems to be the issue. I bought a new SD card, formatted it, I bought two new replacement batteries, and still nothing. The SD card is not an adapter type of SD card it's the full 64 GB card. I'v...
Hi , I am using Canon R5, the video was shows and play in the camera but, connecting to the PC the video size is Zero KB ,What should I do for get that video. I think this an serious issue. Give me a solution for recover the video.
So on the canon 70d - The sound recording option- on this particular camera gives options of ‘on’ or ‘off’ - every other canon I’ve worked with, and I own 3 70D’s, the options are ‘auto’ and ‘manual’ I need ‘auto’ and ‘manual’ to hook up my sound g...
Where is the R8 sound recording menu? The diagram and instructions shows where but I cannot find the menu in my camera. I have sound record on/off only. Not the full menu. The manual also says "Use" followed by a camera icon. What does that mean? th...
Firmware update 1.4 fails to install on my R10. It stops at Step 3/4 with the not-so-helpful message "Failed to transfer the firmware." Any suggestions?
The previous post was marked "Solved" so i am starting a new one as i still need help please. This is what I wrote on tne last post:"Ok, silent is on mode 1, no image preview ... what next? And how do multiple exposure settings work with continuous ...
Hi... As the subject heading notes I cannot insert my SD card into the SD memory card slot. The CF card goes in just fine next to it. The SD card goes about 80% of the way in. I see no obstructions, have tried a different SD cards. No luck. Have had ...
I've been running dual system for a while, with an R5 and an A7C. One thing I use the A7C for heavily is streaming/teleconference, running 4K HDMI output to an Elgato. It seems to be able to do this indefinitely. I had hoped to combine my kit by subb...
I ordered the w-e1 wi-fi converter. I realized I needed to update the firmware. After doing so, the wi-fi still didn't work I didn't know if there was a way to test it to see if it worked elsewhere, but I took it out and put the memory card from that...
On the R6 mk i, if i set the drive mode to 2 or 10 sec timer mode and use the BR-E1 remote, the shutter fires immediately (overriding the drive mode on the camera)But on the mk ii, this is not the case. The remote doesn't override the drive mode set ...
Hello,I am very new to Canon Community, I just signed up a trip to Yellow Stone in Sept, 24 and I thought I would upgrade my old camera before the trip. I have EOS xsi and the lenses I have now are EF-S 55-250MM and EF-S 18-55MM.There is a refreshed...
can someone tell me if a 256 gb memory card is compatible with the 5d mark IV? I was thinking about getting a SanDisk or Lexar 256gb card but i'm seeing some reviews that say the 5D Mark II works with the 128gb card but not the 256gb card. Does any...
Subject | Author | Posted |
04-28-2024 09:09 AM | ||
04-28-2024 06:01 AM | ||
04-27-2024 08:20 PM | ||
04-26-2024 06:00 PM | ||
04-25-2024 12:42 PM |
