04-28-2024 05:09 PM
04-28-2024 05:25 PM - edited 04-28-2024 05:42 PM
Greetings
I'm on my mobile device currently. Is the lighting florescent?
What white balance is the camera using?
~CarePaks Are Worth It
04-28-2024 06:06 PM
AC powered light might change colour slightly due to the mains frequency, while it's normally the brightness it is sometimes the colour temperature. It could also be the brightness change of the light, the camera applying a bluer white balance to the scene, but less of a warm light from the lighting.
When you say the white balance is set manually, what does that mean?
Canon cameras have auto white balance and then several white balance presets such as tungsten, shade, cloudy and fluorescent, plus there is custom white balance and for some cameras kelvin white balance.
Only when set to custom white balance or Kelvin will the same white balance be used across the whole frame.
When a preset like tungsten, shade, cloudy, fluorescent, daylight etc is used these have a little "wiggle room" and the camera can apply different white balance to different parts the image to make an overall pleasing image. Usually the difference is a few hundred Kelvin, but it might be enough for your images. I'm assuming these are JPG images from the camera, if they are RAW and processed in Canon DPP then you see similar, but when using say Adobe Lightroom they use a fixed colour temperature for the whole frame based on the temp and tint sliders.
04-28-2024 07:28 PM
Hi Brian.
"When a preset like tungsten, shade, cloudy, fluorescent, daylight etc is used these have a little "wiggle room" and the camera can apply different white balance to different parts the image to make an overall pleasing image."
Does this mean the camera is analyzing each of the matrix sensor segments and adjusting the white balance individually for each segment?
04-29-2024 09:38 AM
Are you sure about that? Do you have anything from Canon talking about this? This would play havoc with anyone *intentionally* mixing light sources.
04-29-2024 12:00 AM
Mixed lighting in a scene (flourescent, daylight, incandescent, speed light) might cause some color variations in shots like these. Some LED lighting can make for even more noticeable color shifts. The fact that these shots contain a lot of white and neutral grays probably magnifies the effect somewhat.
04-29-2024 09:33 AM
Had the same problem with photos showing a "gold" hue. Professional photographer: Check your WB.
