08-27-2015 10:49 AM
I have a rebel t31 and it was freezing up often after taking pictures. I upgraded to a 70D and I still have the same problem. I am guessing that means I am doing something to create this to happen?! Any suggestions? I have tried new batteries, and that made no difference.
08-27-2015 11:06 AM - edited 08-27-2015 11:07 AM
Are you taking exposures longer than 1 second and have long exposure noise reduction set to ON or Auto?
Long Exposures: Capturing the Passage of Time
Long Exposure Noise Reduction can be set to Enable, Disable, or Auto. In the Auto mode, the camera will determine whether or not it's necessary for exposures of one second or longer. When set to Enable, the camera automatically applies Long Exposure Noise Reduction to all exposures longer than 1 second. (Please note that at shutter speeds faster than 1 second, Long Exposure Noise Reduction is ignored, and has no effect – thus, it can be left "enabled" all the time if you like, and it only is applied in actual long-exposure situations.)
Long Exposure Noise Reduction works quite a bit differently than High ISO Noise Reduction, as there really is no loss of detail. There is one sacrifice however: your camera will be unable to make another exposure until the Long Exposure Noise Reduction has finished. The time that takes is exactly as long as the exposure it was reducing the noise for. So, if you make a 30 second exposure, Long Exposure Noise Reduction will take another 30 seconds of processing time, during which time you will be unable to take another photo with your camera.
What's happening is this: your camera makes its exposure for the image. Long Exposure Noise Reduction then kicks in, and charges the camera's imaging sensor for the same amount of time, making a "dark frame." The camera then compares the noise in the dark frame with the noise generated in the image, and removes any noise that is the same. This method is known as dark frame subtraction.
08-27-2015 12:16 PM
The long exposure noise reduction was actually set to off. It was the default setting and I haven't ever changed that.
08-27-2015 01:53 PM
Exactly what are you doing and in which mode?
08-27-2015 02:50 PM
08-27-2015 08:15 PM
How long does it freeze up? Are you shooting in bursts? If shooting bursts, you will quickly fill up the camera's buffer and it will stop shooting until it catches up. It feels like a long time but really it is only a matter of seconds.
08-27-2015 08:27 PM
@ScottyP wrote:How long does it freeze up? Are you shooting in bursts? If shooting bursts, you will quickly fill up the camera's buffer and it will stop shooting until it catches up. It feels like a long time but really it is only a matter of seconds.
And if the OP is using a bad or slow SD card it can take a long time for the buffer to clear.
08-28-2015 12:25 AM
08-28-2015 06:43 AM
If its simply an issue of burst shooting and filling up the buffer ther is no reason to turn camera off. Just wait until the buffer clears. There is a number at the botttom of the viewfinder just to the left of the green focus confirmation dot. That represents how many burst shots you can take.
Use a fast SD card - one with a 10 in a circle on it.
https://www.sdcard.org/developers/overview/speed_class/
http://media.the-digital-picture.com/Sounds/Canon-EOS-70D-Burst.mp3
08-31-2015 07:30 PM
I will look at and try your suggestions. Thanks!! 🙂
