09-12-2023 09:32 PM
I had seen in another post about a firmware update for the EF 100-400mm f/4.5-5.6L IS II USM (which I discovered the previous 1.0.6 version on mine). I hope this isn't a dumb question but can I do the update via an RF to EF adapter on my R5 or R6ii?
09-12-2023 09:58 PM
I would think that if it is a Canon adaptor, you should be good to go. If you did the download of the firmware update file, it has instructions included.
09-12-2023 11:56 PM
I agree with Bob. If the current FW for the lens displays in the R5's menus, you should be able to apply the upgrade. Please put the "EF008107.lfu" file on the root of a freshly formatted (in camera) SD card. If you have a CF Express card installed, remove it temporarily prior to performing the upgrade. You will also want to use a fully charged battery.
While the behavior that v1.0.7 addresses is rare, I'd install it to be safe.
~CarePaks Are Worth It
09-12-2023 09:58 PM
09-12-2023 11:56 PM
09-13-2023 09:09 AM
Thank you to both people who replied--am glad to hear that. The fix Canon described for the image sometimes "jumping around" is a situation I have sometimes experienced with that lens so I am interested in the update. I keep my camera firmware up-to-date but forget to periodically check on lens updates. Wanda
09-13-2023 09:17 AM
I'm behind with two of my lenses right now as well. I think the updates add focus breathing correction which I don't even have on my body but I'm sure my next one will 😀
09-13-2023 10:38 AM
Version 1.0.7 is supposed to address an IS problem with the lens. Hope it cures your problem. It sounds like your issue is related to image stabilization in the lens.
09-13-2023 02:10 PM
I hope so--I don't see that happen with my other lenses, and, luckily, only rarely with the EF 100-400. Thanks!
09-13-2023 02:16 PM
Let us know if the firmware solves the issue.
09-17-2023 03:10 PM
I updated the firmware a few days ago and have spent a little time testing out the lens. So far so good. Even though the problem occurred only rarely, I feel as if the update will continue to serve me well. Thanks for your input and help!
09-17-2023 03:14 PM
Good news.
