Scanner bad color
Hello, I have a Canon Pixma MG 7550 all in one printer. When I scan color photos the color is terrible.....it turns out mostly red. I cannot see anywhere in the settings to try to fix this. Please help.
The printer will not print in color, despite having sufficient ink. I have confirm that color printing, not grayscale, is the setting for the printer. Additionally, I've tried several methods for resetting the cartridges/printer. I also have performe...
I get Error code 1001 "No tray inserted or no CD in tray" when printing on ip7250 using Easy Photo Print EX.I am sure the tray is inserted correctly (exactly as on the picture on the tray). A printable CD is in the tray. Tried many times, tried switc...
Canon MX 320 printer - i cant find the "Stop-Reset" Key on the printer. which key ist the "Stop-Reset key ?
MX922: I just had a very strange scanning irregularity: When scanning from the flat bed scanner, the image came out rotated about 10 degrees. It repeated. When scanning from the sheet feeder, it scanned correctly. Thinking it was a mechanical err...
Where can I find a driver for my SELPHY CP910 air-connected to my MacBookPro using Version 10.11.5?
why won't my printer print on plain paper settting?
When I send a fax on the Canon multi functional printer MX432, the confirmation page is not automatically printing as indicated in the manual. Please advise. Thank you.
Hi all, Sooo I recently very foolishly purchased this printer 2nd hand. When I print or scan, there are several white lines through the document. I have attached pics to show this and also the inside of the printer. I have tried every clean and check...
MG6360 won't print each morning then I have to reset the password and restart the computer to get the printer to work. I have a mac and do a lot of work from home, so it is very annoying. Takes more time to reset the printer than do the job I need ...
HelloMy MG5250 had a blocked printhead.. as I had error B200. I think I have cleaned it. Now got a power connection problem.Power is on at the wall and Orange/Amber light is on but the Blue light of ON/Off/ Wifi doesnt light up. Do these switches bre...
I have a PIXMA MG8120 Printer with the error message 6A81. I have turned off the power many times as well as unplugging the power source for a full day. There are no obstructions. What do you suggest?
I have a MF 4150 and trying to get it working with new PC running Win 8.1. I have installed updated Win 8/8.1 drivers and toolbox as shown in another post on the forum. All functions will work but when I tiurn off the MFP and turn it back on the s...
No mkatter wqhat I try I cannot get rich black text from my MX922. Any help on this problem. I have read answser about other canon printers with the same problem, surely Canon is aware of this and has a fix somewhere hidden.
Subject | Author | Posted |
06-12-2024 09:24 AM | ||
06-11-2024 10:55 PM | ||
06-11-2024 04:53 PM | ||
06-11-2024 09:39 AM | ||
06-10-2024 01:50 PM |
