12-05-2023 01:54 PM - last edited on 12-06-2023 09:30 AM by Danny
Hello. I have a Pixma TS 6020 that was purchased in 2017. It is a combination printer and scanner. All features were functioning until recently. I am running a Mac with OS Sonoma 14.1.2.. I am currently still able to print, however, I am getting error readings when I try to scan. I re-dowloaded the driver but it still doesn't scan. Any help would be greatly appreciated.
12-12-2023 12:47 PM
I am also having this issue but no error code. It just looks like it is scanning but nothing happens. I have scanned numerous articles, pictures, records but all of a sudden it won't work. Suggestions?
12-20-2023 10:38 AM
Are you scanning directly from printers and scanners or are you using IJ Scan Utility?
12-20-2023 12:08 PM
I am using Canon IJ Scan Utility 2
12-21-2023 08:05 AM
Wireless connection or USB connection?
12-21-2023 11:37 AM
wireless
12-22-2023 12:52 PM - last edited on 01-09-2024 09:26 AM by Stephen
While there is no scanner driver for MacOS Sonoma, there is one for Ventura V13 that we can try to use as a workaround. Please click HERE and when the page opens, change the operating system to MacOS Ventura V13. Once that is done, download and install the ICA Driver Ver.5.0.0
Once the driver is reinstalled, remove the printer one more time and add it back. Then open IJ scan Utility and make sure it is listed as TS6300 series network and then try to scan again.
01-01-2024 02:10 PM
Hello Arthur... Happy New Year and thanks for helping! Before I try this can you tell me if I would be actually changing my Macs OS back to Ventura or is this just in the Canon settings?
01-08-2024 10:42 AM
This is just changing the setting on the Canon website so you can access the scanner driver. This will not change your computer operating system in any way.
01-09-2024 09:13 AM
Thanks.... When I clicked on your link "HERE" it just brings me back to this page so I'm not sure where I'm supposed to change the OS. Can you tell me where exactly I should change it? Lisa
