02-29-2016 05:37 PM
I am a total newbie. Purchased this camera for food shots. Trying to set up the Rebel T5 with the Speedlite. I connected the EOS under the "P". I set the speed lite to slave. I went to camera menu and made sure flash firing was enabled.Then went to built in flash function setting. Flash mode is greyed out to e-ttl2. Can't change it. Shutter sync is 1st curtain. Flash exp.comp is in the middle and then finally e-title 2 meter is set on evaluative. All other choices (external flash function setting, external flash cf.n and clear ext. flash C.fn setting only gives you a message as MENU NOT AVAILABLE. What am I missing?
02-29-2016 06:35 PM
Is the speedilite on the camera?
You have to set the T5 as the Wireless master. Look in the manual under Wireless Flash.
02-29-2016 07:37 PM
@Maddyg wrote:I am a total newbie. Purchased this camera for food shots. Trying to set up the Rebel T5 with the Speedlite. I connected the EOS under the "P". I set the speed lite to slave. I went to camera menu and made sure flash firing was enabled.Then went to built in flash function setting. Flash mode is greyed out to e-ttl2. Can't change it. Shutter sync is 1st curtain. Flash exp.comp is in the middle and then finally e-title 2 meter is set on evaluative. All other choices (external flash function setting, external flash cf.n and clear ext. flash C.fn setting only gives you a message as MENU NOT AVAILABLE. What am I missing?
If you are using a T5 and not a T5i, I'm pretty sure the built-in flash of the T5 is NOT capable of being used as a Master Flash to control the 430EX II (or any other flash) as an ETTL slave flash.
02-29-2016 08:40 PM
03-01-2016 08:07 AM
@Maddyg wrote:
Oh No!! I think you are right. What are my options? The whole idea was to use lighting to help with these food shots.
There are a couple of options, the least expensive is to use an off camera ETTL flash cord like the Canon OC-E3. I have the genuine Canon OC-E3, and a longer Yongnuo version and they are identical in quality.
The other option is to buy a Canon 90EX, that is the least expensive option to use as an optical wireless ETTL Master flash.
Note, with both of these options the remote 430EX II becomes the only flash, the built-in flash won't work when the OC-E3 is attached, and the 90EX isn't powerful enough to both control other flashes, and act as a flash while doing so.
03-12-2016 11:18 AM
@TTMartin wrote:
@Maddyg wrote:
Oh No!! I think you are right. What are my options? The whole idea was to use lighting to help with these food shots.There are a couple of options, the least expensive is to use an off camera ETTL flash cord like the Canon OC-E3. I have the genuine Canon OC-E3, and a longer Yongnuo version and they are identical in quality.
Could he use the 430EX II as an on-camera master and a 90EX as the off-camera slave?
03-12-2016 05:22 PM
430EX cannot be a master.
