11-04-2019 10:00 AM
Hi
I have a Canon Pixma Pro 100S and I get great results printing graphic illustrations on matt card except for areas of solid black. I use a Mac - High Sierra operating system.
I print direct from Adobe Illustrator and use the Fine Art Paper 1 setting with an Uncoated FOGRA29 profile and let Illustrator determine colours. I use a Mac - High Sierra operating system.
It comes out more of a very dark grey I have tried lots of different settings, papers and different CMYK versions of black and the best result I can get is with C50 M50 Y50 K100.
Do you have any suggestions on how to get a truer black?
Thanks for any suggestions!
11-05-2019 02:42 PM
1. Use, load - paper profiles. Matte, Semi-gloss, Prt, Gloss. Photo paper manufacturers provide them! Choose a profile for paper. 2. Make a black and white photo initially and print it in color. Black will be great. 3. Lighting, consider lighting lamps when printing, the light from them also gives distortion. 4. Change the CMYG on sRGB.
11-06-2019 04:45 AM
Thanks for your suggestions!
11-05-2019 04:39 PM
11-06-2019 04:45 AM
Thanks for your suggestion John. I will try getting some new ICC profiles - I think this is the problem isn't it. The paper doesn't have its own profile unfortunately.
11-06-2019 08:39 AM
@claref wrote:Thanks for your suggestion John. I will try getting some new ICC profiles - I think this is the problem isn't it. The paper doesn't have its own profile unfortunately.
If you select Canon Matte Photo Paper there is a Canon ICC profile you can select.
