08-27-2022 04:57 PM
A short time ago, I was playing with Windows 10 screen resolution, including a custom screen resolution. Since then, Quick Menu has been displaying in the upper left quadrant of my screen instead of at the lower right. This did not correct when I returned to the Windows-recommended resolution of 150%. I cannot drag the display to the lower right. Is there any way to fix this?
Processor Intel(R) Core(TM) i3-1005G1 CPU @ 1.20GHz 1.19 GHz
Installed RAM 4.00 GB (3.75 GB usable)
System type 64-bit operating system, x64-based processor
Edition Windows 10 Home
Version 21H2
OS build 19044.1889
Experience Windows Feature Experience Pack 120.2212.4180.0
08-28-2022 02:22 PM
Are you using the correct resolution setting for your display? It will say "Recommended" on the selection list.
Don't know what you mean by "Windows-recommended resolution of 150%." That's not a resolution term.
Using resolution other than the recommended for your display can cause a messed-up rearranged desktop.
08-28-2022 02:54 PM
This screen print shows my current settings. I was playing with the scale setting when my problem occurred. I immediately set scale back to recommended, but the problem still persists.
08-28-2022 03:16 PM
Yeah, changing the SIZE of things (different than the RESOLUTION) can cause rearranging as well. Things fit differently on the desktop when the size is changed. Set size , THEN move things where you want them to be. Restart the computer. Does the arrangement stay as you put it?
