11-08-2023 01:37 PM
Got a new modem. Instructions say to press button on back, which turns out is wrong because it just resets and takes you offline.
Now I am back online and I see my network in the list on the printer, but connecting that way does nothing either.
It does not ask me for a passphrase or number.
Called but they won't help, hung up on me.
PLEASE! I'm desperate to get my printer back working.
11-10-2023 03:45 PM
ON MY GOSH! Simple fix! THANK YOU DAVID!
Called Canon again and he told me that the router was TOO CLOSE to the printer. Yes it was 6" away, never did I think that would be an issue since it was seeing all the neighbor's networks, an acre away, but not mine!?
After we cleared all the LAN settings I moved the printer just a few more feet away and VOILA! We are finally online. I knew there was some simple solution since I had seen the network show up on the screen once before, but then mostly not. I did not know what was stopping it from showing up again.
Who knew the new routers had a 'trunk' signal distance and that if your router is too close it could be a problem? I always thought it being too far away was an issue, but never too close.
02-21-2024 06:09 PM
Yes, this was my problem too. Don't understand what happened. I might have moved them closer together but suddenly the printer stopped working with the same symptoms. Moved them a few inches apart and then it all worked fine.
11-09-2023 08:46 AM
Thanks for joining the conversation, themaclady!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
11-09-2023 10:19 AM
I signed up and paid $20 for an answer that did not work.
11-10-2023 03:10 PM
If the solution you were provided didn't work, you're welcome to call back at no additional charge within a certain number of days. Our PIXMA support team is committed to finding a resolution that fixes the issue permanently.
We look forward to your call!
11-10-2023 03:18 PM
OK I did not know.. thought I had to pay each time.
11-10-2023 03:07 PM
I am not getting the help I need! I have set up three bands, 2.4, 5 and 6. I set the 2.4 on WPA2 and it still doesn't even SEE the network... the router is sitting right next to the printer.
Why can't anyone help me with this?
11-10-2023 03:45 PM
02-21-2024 06:09 PM
02-21-2024 06:25 PM
What gets me is, Canon knew about this but after hours of discussion with Comcast not one of their techs suggested it and this is their new router!
