09-09-2016 02:38 AM
09-09-2016 04:10 PM
Check your manual. There will be a way to check level using the LCD on the printer.
Plus, when you go to print something the driver should have a popup window that gives the ink level.
09-09-2016 07:22 PM
09-09-2016 07:59 PM
09-08-2017 01:48 PM
Press the MENU button
Press the right arrow (by the OK button) to navigate to additional MENU items
Navigate to Settings
Press OK
Right arrow to Estimated Ink Levels
Press OK
That should bring up a graphic showing an estimate of your ink levels
