05-02-2016 03:01 AM - edited 05-02-2016 03:06 AM
My canon powershot elph 360 hs will not connect to my router. I select my router SSID and enter what I know to be the correct password, But i searched and never finds it. Anyone have any suggestions? I am running mac OS El Capitan.
05-04-2016 03:38 PM
Hi Jbsylvester,
When they created El Capitan, Apple changed the way that Wi-Fi is accessed. Because of this, the current version of the Canon CameraWindow does not support a wireless connection with the Mac El Capitan operating system. Canon is aware of this issue and is working on a solution. Unfortunately, no estimate is available regarding the arrival of a replacement version of the Canon CameraWindow. I regret the difficulty this causes.
You may still transfer images and movies using a USB cable. Your camera will accept a mini-b to USB cable. The USB terminal is located on the right side of the camera (as you're holding it to take a photo) under a small door.
05-04-2016 03:38 PM
Hi Jbsylvester,
05-04-2016 08:05 PM
05-08-2016 10:15 AM
El Captain had been out for 4 months when you relased this camera 4 months ago. This is taking too long. Please elevate this issue.
02-06-2017 05:15 PM
It's now been seven months and there still isn't a solution.
12-02-2021 12:55 PM
Having this SAME ISSUE with Catalina. Wondering if you never fixed it???
