10-05-2016 04:21 PM
I have noticed that when camera focal length shows 4mm, I always get rounded corners. Is there anything I can do to avoid it.
10-05-2016 04:35 PM
Try removing the hood?
10-05-2016 04:35 PM
It is vignetting, but not the vignetting everyone usually talks about. Typically vignetting is about 1 stop, yours looks like about 12. 8^) This looks to be a lens misalignment that is allowing the lens image circle to be visible. I think you need to send it for repair. Do you have anything on the lens like a hood or third party adapter?
10-05-2016 04:41 PM
The lense does not have a hood. What I have noticed by checking JPEG exif data is it happens only when focal length is 4MM. I don't see this effect in any other time.
Do I still need to send camera for repair?
10-05-2016 04:51 PM - edited 10-05-2016 04:52 PM
That is the wide end. Clearly something is misaligned and might be preventing you from getting all the way to 3.8 mm, I would send it in.
Or call Canon. Maybe it is normal for this camera, but I doubt it.
10-05-2016 05:46 PM - edited 10-05-2016 08:53 PM
@nhrdls12 wrote:The lense does not have a hood. What I have noticed by checking JPEG exif data is it happens only when focal length is 4MM. I don't see this effect in any other time.
Do you have a 'protective filter' on the lens?
If so remove that.
10-05-2016 10:24 PM
This is not Vignetting. It is caused by the wide angle lens and the end of the lens itself. To correct this, zoom in just a bit (try 6 mm or 8 mm). This will usually correct the shot. Anytime I have my macro lens on my camera, and I shoot a wide shot, this happens as well.
10-06-2016 06:34 AM
It doesn't look like vignetting to me. The "event horizon" of an image circle is usually not that clean and defined.
