04-25-2024 05:13 PM - last edited on 04-25-2024 05:18 PM by Tiffany
Hi, when I change the battery in my SX60HS, it loses the time and date information. What's happening here?
Thanks,
Bob
04-26-2024 03:28 PM - edited 04-26-2024 03:29 PM
Ummmm, the simple explanation is that the internal date/time battery is depleted, so it does not charge from the main battery. So you lose date/time instantly if the main battery is removed.
The FIX would be to have Canon replace the internal date/time battery, but like Tronhard said, that's not likely on this 10-year-old camera. You have to ask Canon.
04-26-2024 12:50 AM - edited 04-26-2024 12:51 AM
To clarify, is your situation that the camera being powered up, then turned off and a new battery installed causes it to lose the date and time, or has it been some time since you have used the camera with a battery before using the new battery?
If the battery has been removed or discharged for about 3 weeks, the data and time will be lost. Even if you put a new battery in, it will take about 4 hours to power up the EPROM to keep the date/time again.
04-26-2024 10:19 AM
Hi, this is an immediate thing. I take the one battery out and immediately replace it with a fully charged one. The one that is removed is not fully discharged. I always make sure that the camera is turned off before pulling the battery. While I've had extensive experience with digital cameras, I've never had one do this. In this instance, I started with a full battery, and was shooting heavily, 180 shots in about an hour (wildlife shooting), and the battery was down to the last bar when I finished.
04-26-2024 01:58 PM - edited 04-26-2024 02:01 PM
Thanks for your clarification. I had an SX60HS some time ago, so this is somewhat from memory - I would suspect that the EPROM that keeps the date and time may be faulty and not holding the data. Assuming there is a consistent energy supply, it should hold its settings. The SX60 is an old camera and it may simply be a function of its age. I would very much doubt that it would be serviced now, and if it is was, that it would be economically viable to do so.
So, I suspect that if is not critical and, if there are no other symptoms, then keep on taking shots but perhaps see this as a straw in the wind and start considering your options in case it fails completely.
04-26-2024 04:39 PM
Thank you, this is logical, and it's probably not worth the cost or effort to have the battery replaced. My time goes back to when cameras didn't have batteries, built-in meters and all this other stuff. A simpler time for sure, but not one I would readily want to return to...
04-28-2024 02:48 AM
A couple of my older Canons had a small user-serviceable memory battery to retain the time and date settings. It should show in your user manual if that's the case for your SX60HS. Most newer models it seems use a more "built-in" battery or possibly even a capacitor that charges from the main battery to maintain memory. If it's a capacitor that's completely lost its charge, it may take a fair bit of time for it to "form" to where it will hold a charge again. Or the capacitor itself may have just failed.
04-28-2024 02:52 PM
We've already established that the SX60 HS does not have a user-replaceable battery.
