10-29-2013 11:51 AM
Canon MG6320
Someone hit the WLAN set up on the touch screen. Now the WiFi light on the printer is on all the time & I can't figure out how to turn it off. We don't have WiFi.
The closest I could find in the manual said to go to "IJ Network tool" in All programs/Canon/Utilities, but I don't have that.
How to exit set up & turn the light off?
Thanks.
11-07-2013 04:01 PM
Hi Baymare,
To disable the Wireless LAN on your printer, follow these steps:
If you have any other questions, please feel free to Contact Us!
11-07-2013 04:01 PM
Hi Baymare,
11-07-2013 07:42 PM
11-07-2013 07:54 PM
Hi Baymare!
Help your fellow Canon Forum members. Click the "Accept as Solution" button if your question was answered to your satisfaction!
11-12-2016 09:31 AM
Great solution, it worked! Thank you.
11-21-2020 03:57 PM
Not able to set up scanning. I'm trying to disable the wireless LAN on my D1650 because all of the setups seem to go to the wireless, and I have a USB connection to my PC. When I go to menu/preferences/network I don't see any off/on selection available. It seems to be disabled (but hard to confirm) when I select "direct connection". Is that USB? Regardless, the scanner does not appear in Windows and the scan software if for scanning "from the PC" and I want to scan while at the scanner.
All software/drivers are the latest versions.
Thanks!
Ed
11-21-2020 04:04 PM
Ignore ... finally found scanner and it's connected via USB. Now on to the mysterious RemoteUI. Hope it's all worth it. Printing is great, but scanner setup has been a nightmare. My sheet scanner (EPSON D-510) was not much more than load software and plug in.
