08-22-2023 09:21 PM - last edited on 08-23-2023 09:21 AM by Danny
Recently had a power surge during a storm that turned off power for about an hour. When power returned, the printer display showed this message: "TURN THE MAIN POWER OFF/ON. E225-0001. IF THE DEVICE DOES NOT RECOVER, CONTACT YOUR DEALER..." Repeated recovery attempts have been unsuccessful. Has anyone ever had this happen and, if so, what was the resolution? I purchased this printer in 2015 and the local repair shop (small town) doesn't service printers.
08-29-2023 02:47 PM
Not sure this will work. Turn it off then pull the plug. wait for a bit and try it.
08-29-2023 06:50 PM
Nope, didn't work, same error message displayed. I think I'll probably just buy a new printer :>( . Bummer.
08-29-2023 09:27 PM
Sorry! did you try tech support?
08-29-2023 11:20 PM
I tried that once and got no reply, but I'll try again---thanks for reminding me.
11-02-2023 04:14 PM
Hello,
The error would point to a problem with the hardware at this point. You can try unplugging the printer from the power and then pressing the power button 10 times while the printer is unplugged. After that, you can plug the printer into a different power source and you can try turning it on. If the error does not clear when the printer turns back on, it looks like the hardware is damaged.
