Reply
Occasional Contributor
full frame suggestions
Hello ...I'm new to this forum and found some very informative feed back to some of the members questions so i figured id take some time to get some opinions for myself about my particular question. I currently own a 7dmk2 with a verity of "L" lens
( EF 70-200 f/2.8L IS II USM,  EF 100-400 f/4.5-5.6L IS II USM.) as well as a sigma 17-50 f/2.8 and 10-16 f/2.8. I mostly shoot sports and action type events as well as wildlife. I want to shoot more indoor activities and landscape/astro type work. I love my 7dmk2 and was wondering what your opinions are on a full frame camera since i already have the action type shots covered with the 7dmk22?
Honored Contributor
Re: full frame suggestions
Your Sigma lenses are made strictly for APS-C camera bodies, like your 7D2. The 7D2 should be up to task of landscape photos. Invest in a 600EX RT III strobe for indoor shots, instead of a FF body. Buying a FF body means buying lenses for indoor shots.
Thank you for responding to my post and your suggestions as to using a strobe for indoor shooting. I have a flash and use it when i can indoors. I was planning on upgrading my sigma lens to FF "L" series lens. I was planning on shooting all my action phots with the 7dmk2 and buying a FF the rest of the time. My thoughts were do i buy the new 6dmk2 , 5dmk3 or is it worth steping up to the 5dmk4.
Honored Contributor
The best of that trio is the 5D4.  The best buy in a full frame is the entry level 6D, which can be purchased through Canon’s Online Refurbished Store at a significant discount.
For the current selling prices, the 5D3 is probably a better buy than the 6D2.  The 5D3 has a better build and dual card slots.  The 6D2 has higher resolution, plus both built-in Wi-Fi and GPS.
If you are accustomed to the button layout of a 7D2, then I would suggest either the 5D3 or the 5D4.  It’s your budget, take your pick.
Thanks again for insight. I was thinking that if I went with the 5dmk4 ..i would be set for many years to come. Out of curiosity...what gear do you shot with?
Honored Contributor
[ Edited ]
I have the lenses you cited, plus the EF 16-35mm f/2.8 II USM, and a couple of other “L” zoom lenses.  I shoot with a 6D, 7D Mak II, 1D Mark IV, and I am trying out the 6D Mark II, which I picked over the 5D Mark III.  I liked the AF system in the 6D2 better than the one in the 5D3, and didn’t want to spend nearly double for a 5D4 to get something comparable in a 5D body.
I am a camera nerd, not a professional photographer.
Esteemed Contributor
I own a 5D IV, and a III, and I had the II before that (although I’ve sold the II).  I _really_ like the Mk IV.
However... for “astro”, everything is manual focus anyway (so the AF system doesn’t matter) and you don’t even use the metering system (even that is manual for astro work).  Basically you want a sensor and a means to tell it when to take the shot and how long to hold the shutter open.
For astro, it’s basically all about sensor performance and the body features aren’t so important.
BTW, I assume you plan to do astrophotography with normal camera lenses and not through a telescope.  If you want to shoot through a telescope then a full frame camera kinda opens a can of worms.  Most scopes can’t produce a nice flat field that large (the stars will start going soft in the corners unless you have a vETG high end scope.  Also you can’t use a typical 2” nosepiece with t-ring adapter because the t-ring adapter’s inside clearance is about 37mm across and the camera sensor is about 44mm across... so you get strong vignetting in all the corners (there are camera nosepieces for full-frame cameras that get around this.)
For other indoor purposes... sure a 5D IV is fantastic but you can’t use your APS-C lenses and your long lenses are probably too narrow for most indoor use (unless it’s a very big room so you have the space to shoot subjects from a distance).  So you’d have to factor in the cost of at least one additional lens.
Tim Campbell
5D III, 5D IV, 60Da
VIP
IMHO, I would buy the 5D Mk IV or nothing. The other FF options are just going to cost money and offer little to nothing.
There are a few lenses that you can add if you have the $3000+ (5D Mk IV) to spend.
"( EF 70-200 f/2.8L IS II USM,  EF 100-400 f/4.5-5.6L IS II USM.) as well as a sigma 17-50 f/2.8 and 10-16 f/2.8 ???"
The first two are great, the ladder two not my choice or favorites.  This is a sample of what I would buy from what you said.
Sigma 18-35mm f/1.8 DC HSM Art Lens for Canon    (7D2 only)
Tokina AT-X 16-28mm f/2.8 Pro FX Lens   (will be fantastic on a FF, too)
Canon EF 50mm f/1.8 STM Lens           (will be fantastic on a FF, too)
Canon EF-S 17-55mm f/2.8 IS USM Lens          (7D2 only)
These are incredible lenses.
The flash would be so far down the list of what to buy as to not even make it on the list.  Forget it.
A lot of Canon stuff. Along with, a lot of other stuff.
VIP
On second thought you should buy the Sigma 18-35mm f/1.8 DC HSM Art Lens for Canon no matter what else you decide to do.
Sell the "sigma 17-50 f/2.8"  Smiley Happy
Honored Contributor
If you have the budget for a 5D Mark IV, then go for it.  As I have noted, you will want to buy a shorter lens than your two “L” lenses, not unless all you plan to shoot are action shots.
My two favorite walk around AF lenses are the EF 16-35 f/2.8L II USM, and the EF 50mm f/1.4 USM.  I had the “nifty, fifty”,  EF 50mm STM, and gave it to one my sons, and it really is a pretty sharp lens.  The walk around lens to have is probably the EF 24-70mm f/2.8L II USM.
If you are interested in astrophotographers with conventional DSLR lenses, then you want to invest in a fairly robust tripod, with a high quality head.  With a full frame body, and professional grade lenses, that can present an off-center load that will tax the stability of most consumer tripods.  Look for something than can handle in excess of 30 lbs, proferably more than 50 lbs.
powered by Lithium
