Reply
Occasional Contributor
Accepted Solution
Upgrading my Camera
Hello All,
I have purchased a new Canon 70 - 200 2.8 lens and I am thinking about upgrading the my current camera (Canon T5I) to a Canon 6D.
Question:  Do I need to upgrade? My current camera has a 18-135 canon lens which of course I would need to replace
Thanks all
Chomp
Esteemed Contributor
Re: Upgrading my Camera
The main reason for replacing a T5i with a 6D is low-light performance. The 6D is significantly better, allowing you to use higher ISO settings without introducing unacceptable noise. If you do most of your shooting in daylight, you may not find that to be very important.
There are some other differences as well, which you can determine by comparing the two cameras' published specs. But if you don't already know what most of them are, they probably don't need to affect yuor decision.
If you do upgrade to a 6D, you will indeed have to get a new lens. The usual choice is the EF 24-105mm f/4 IS USM. It won't have nearly the reach that the 18-135 has on your T5i; but your new 70-200 renders that moot.
Bob
Boston, Massachusetts USA
Thank you very much for the information. Your information makes for an easy decision.
I think I will wait for a bit to upgrade to the 6D...
Chomp
VIP
[ Edited ]
"I think I will wait for a bit to upgrade to the 6D.."
IMHO, the main most reason to 'upgrade' to a 6D is for full frame vs crop.  Taking in consideration all the advantages of FF vs cropper.  It is also true that the crop sensor has some advantages over FF.
 The low light performance has more to do with pixel size than if does with sensor size.  The general thought is a bigger sensor will have bigger pixels.  Therefore better low light gathering.
However, this may or may not be the case.  In the case of the T5i and the 6D the difference is substantial.  4.5 vs 6.5 if my feeble memory is correct.  But the real improvement may come with the most current electronics.  It is pretty safe to say a newer Rebel, T7i, will perform better than your T5i in low light, too.
A lot less stuff for 2018 but still a lot of Canon stuff. Along with, a lot of other stuff.
Thanks ebiggs,
You make some good points. I guess I will stay with the T5I for now.
If I do move to the T7I, I think I will still need to contend with the 1.6 effect on the 70 - 200 lens. Of course with my really feeble memory, I could have the whole thing backwards
Thank again
Chomp
VIP
You are correct. The 70-200 will actually act like a 112-320mm.  This can be either an advantage or a disadvantage depending on how you intend to use it.
powered by Lithium
