11-23-2023 01:11 AM
That's the question.
11-23-2023 10:32 PM - edited 11-23-2023 10:35 PM
I'm not sure if this link is permitted here, so if you don't see my link, check to see if they have the info you are looking for at DXOMARK com.
Newton
11-24-2023 04:08 AM
Thank you, but I already saw that and couldn't make head or tail of it. I'm looking for something like these: Click to show
Such graphs are easier to find with older more common cameras. Wish Canon had a Gmail so I could contact them directly.
11-24-2023 06:55 AM
Why you need to know might help answer the question.
While not specific to the EOS R5, these papers compare Canon sensors to other camera brands.
https://arxiv.org/abs/2304.11549
Cite as: | arXiv:2304.11549 [eess.IV] |
A number of problems in computer vision and related fields would be mitigated if camera spectral sensitivities were known. As consumer cameras are not designed for high-precision visual tasks, manufacturers do not disclose spectral sensitivities. Their estimation requires a costly optical setup, which triggered researchers to come up with numerous indirect methods that aim to lower cost and complexity by using color targets. However, the use of color targets gives rise to new complications that make the estimation more difficult, and consequently, there currently exists no simple, low-cost, robust go-to method for spectral sensitivity estimation. Furthermore, even if not limited by hardware or cost, researchers frequently work with imagery from multiple cameras that they do not have in their possession. To provide a practical solution to this problem, we propose a framework for spectral sensitivity estimation that not only does not require any hardware, but also does not require physical access to the camera itself. Similar to other work, we formulate an optimization problem that minimizes a two-term objective function: a camera-specific term from a system of equations, and a universal term that bounds the solution space. Different than other work, we use publicly available high-quality calibration data to construct both terms. We use the colorimetric mapping matrices provided by the Adobe DNG Converter to formulate the camera-specific system of equations, and constrain the solutions using an autoencoder trained on a database of ground-truth curves. On average, we achieve reconstruction errors as low as those that can arise due to manufacturing imperfections between two copies of the same camera. We provide our code and predicted sensitivities for 1,000+ cameras, and discuss which tasks can become trivial when camera responses are available.
https://arxiv.org/pdf/2304.11549.pdf
https://eprints.ncl.ac.uk/235852
Estimation of the spectral sensitivity functions of un-modified and modified commercial off-the-shelf digital cameras to enable their use as a multispectral imaging system for UAVs
Lookup NU author(s): Dr Elias Berra, Dr Rachel Gaulton
This work is licensed under a Creative Commons Attribution 4.0 International License (CC BY 4.0).
Abstract
Commercial off-the-shelf (COTS) digital cameras on-board unmanned aerial vehicles (UAVs) have the potential to be used as multispectral imaging systems; however, their spectral sensitivity is usually unknown and needs to be either measured or estimated. This paper details a step by step methodology for identifying the spectral sensitivity of modified (to be response to near infra-red wavelengths) and un-modified COTS digital cameras, showing the results of its application for three different models of camera. Six digital still cameras, which are being used as imaging systems on-board different UAVs, were selected to have their spectral sensitivities measured by a monochromator. Each camera was exposed to monochromatic light ranging from 370 nm to 1100 nm in 10 nm steps, with images of each step recorded in RAW format. The RAW images were converted linearly into TIFF images using DCRaw, an open-source program, before being batch processed through ImageJ (also open-source), which calculated the mean and standard deviation values from each of the red-green-blue (RGB) channels over a fixed central region within each image. These mean values were then related to the relative spectral radiance from the monochromator and its integrating sphere, in order to obtain the relative spectral response (RSR) for each of the cameras colour channels. It was found that different un-modified camera models present very different RSR in some channels, and one of the modified cameras showed a response that was unexpected. This highlights the need to determine the RSR of a camera before using it for any quantitative studies.
https://eprints.ncl.ac.uk/file_store/production/235852/2A11815A-0BAA-4D52-A17A-F866376C58E3.pdf
This paper explains the design of Canon sensors with DPAF: https://www.imagesensors.org/Past%20Workshops/2015%20Workshop/2015%20Papers/Sessions/Session_1/1-03-...
11-24-2023 02:04 PM
@Bobwithbigbelly wrote:Such graphs are easier to find with older more common cameras. Wish Canon had a Gmail so I could contact them directly.
You can go to the Canon USA Support web site, scroll to the very bottom and click the "[+] Feedback" link. They don't make it easy to find 🙂
Newton
11-24-2023 07:31 AM
Illiah Borg created a spectral response curve for the EOS R3 bare sensor with no lens. I have been told that often the curves are similar for all sensors from a given manufacturer from about the same time period.
https://www.dpreview.com/forums/post/65726551
11-24-2023 09:45 AM
How to create your own and some examples.
At this link, you may search for Canon EOS R5 and view a graph. So far as I can understand, it is made from the numbers that are used to convert raw photon counts into a color image: https://color-lab-eilat.github.io/Spectral-sensitivity-estimation-web/
I might guess that the measurements made by Canon engineers during the development of the sensor are trade secrets, but the resulting images are not. So, it might be possible to reverse engineer the portion of the spectrum captured by the sensor that is used for creating color photos.
11-24-2023 09:48 AM
LOL. Or, as I said yesterday...
11-24-2023 02:53 PM
@johnrmoyer
So you want to know why I want the spectral graph? It's because I do astrophotography and I want to use narrowband filters with my unmodded camera, which is possible, but I need to know the sensitivity for 656nm (H-alpha) and 500nm (OIII) so that I can buy the right filter. Thank you for the links (especially the "color lab eilat" link) and the long writing.
@FloridaDrafter
Thanks for showing me where to go. Wonder why Canon wants to hide their Gmail.
I will compare what Canon shows me (if they show me anything) with the Color Lab Eilat graph, and I will make a conclusion.
11-24-2023 02:57 PM - edited 11-24-2023 02:57 PM
There is something wrong with the Canon Feedback links. My antivirus flagged it because it contains a phishing virus and site cannot be reached anyway. I'm not going there.
