04-03-2015 12:31 PM
04-03-2015 05:19 PM
A better lens is always the correct answer.
But a great lens will not be great on a poor camera. A poor camera will certainly compromise the best lens in the world, too.
To be brutally frank, what you have is not real "great". So upgrading any of it or both is going to make a big deal. It is not the number of mega-pickles that makes the difference, persay. A 18MP sensor made 7 years ago will not be as good as a 18MP made in 2015. Things just get better.
Being limited to a grand, I woul still opt for a better lens. Perhaps the Canon EF-S 17-55mm f/2.8 IS USM. Notice how it is a constant f2.8 aperture? But it is not a cheap lens at about $900 bucks.
The Rebel T5i runs around $600. So if you did decide to get this pretty nice combo it would be well over a thousand at $1500.
Maybe get one at a time?
04-03-2015 05:46 PM - edited 04-03-2015 06:19 PM
04-03-2015 09:01 PM
ebiggs and scotty are giving you solid advice. I've seen people pick nits over the "best" camera ... agonizing over details like one camera's ISO performance outperforming another by a fraction of a stop. Meanwhile... they're using lenses which are resulting in the loss of a full 2 or 3 stops of light. Having good "glass" is a huge advantage.
Most professional photographers are not making incomes that allow them to spend without consideration of the price tag. And yet... these same pros will pick lenses that cost thousands of dollars. It's not because they want to... not becuase they have a cash-flow that allows them to buy anything without having to check the price tag first... they buy the lens because it REALLY makes a difference in their work.
When Canon introduced the T2i body, they also came out with a brand new 18MP sensor and a nice little bump in ISO performance. But that same sensor was then used in the T3i, T4i, and T5i (and also the 60D and 7D). The T6i, 70D, and 7D II all have newer sensors... but they're all in a higher price category.
You could buy a refurbished or used T3i, T4i, or T5i and gain at least a full stop (maybe even a little more) of higher ISO with lower noise... but it sounds like you need more than just an extra stop. A lens can provide at least 2 full stops (maybe more.) A lens and body combined would get you at least 3 full stops (maybe 3.5). 3 stops is 8x more light -- so that's fairly significant.
04-04-2015 01:02 PM
Thanks to all three of you.
I am leaning towards getting the T5i, as with the T6i coming out, it is now a good deal, and represents a significant improvement over my 450D. I have located a used one with shutter count in the hundreds for around 500 including the stock 18-55 (which I would like, as I replaced my broken one with a 28-70)
450D T5i
Digic3 DIGIC 5
12.2 mp 18
3.5 fps 5.0 fps
ISO 1600 ISO 25600
From what I read the DIGIC 5 was a much bigger improvement over the 4 than the 4 was over the 3, so I am also hoping for overall improved quality and performance, not just indoors. Video, and articulating touch screen are also features that I didn't have before.
The ISO is the interesting one..allowing you to shoot at up to 25600 instead of 1600 implies to me that CANON believes that they have improved by 4 stops, which I assume most of you don't believe is the case. The way I see it, I had enough light on my current camera at 1600, I just didn't like the quality...but if I shot at 1600 or 3200 on a camera that went to 25600, I'd be 3-4 stops below the max ISO.
I did read another thread and after following a link, took some time looking at photos taken at high ISO.
Note: I have also found a T3i that I could probably offer under 350 for, but I think I am leaning towards the T5i.
04-04-2015 01:32 PM
The ISO is improved... but you're wise to inspect images at high ISO and evaluate what you think of the noise.
As you increase ISO, you also increase noise. Better chips can keep those noise levels down. But manufacturers are allowing us to set ISO levels that result in more noise than previously. In other words, while you can set ISO 25600, you probably will not be happy with the noise... even at 12800. You might be "ok" with the noise at 6400.
Noise tends to be stronger in darker areas of the image (shadow, etc.) and much weaker (or nearly non-existent) in the highlight areas of the image. When you use de-noising algorithms, they basically take each pixel and inspect that pixel's value as compared to all the surrounding pixels. If you slightly "average" each pixel to it's surroundings, you naturally bring down the noise... but you also have the side-effect of softening the whole image (so there is no free lunch.)
Some photo editors allow you to selectively apply an effect -- so you can "brush in" noise reduction only in the shadow areas and leave the highlights alone. I use a program called Noiseware Pro which allows you to "tune" the noise levels and aggressiveness of the software. I can set how aggressive I want it to be in the shadows vs. midtones vs. highlights, etc. I can also tell it if I've mostly got a problem with "chroma" noise vs. "luma" noise, etc. This allows me to knock back the noise in the worst places, but avoid softening the highlight details (where there wasn't much noise to begin with.)
I never try to eliminate all noise (otherwise your subjects have skin that looks like plastic.)
04-04-2015 02:02 PM
Thanks Tim.
@TCampbell wrote:... manufacturers are allowing us to set ISO levels that result in more noise than previously. In other words, while you can set ISO 25600, you probably will not be happy with the noise... even at 12800. You might be "ok" with the noise at 6400.
This is what I suspected with the huge increase in ISO. Also, I was looking through some old shots and realized that I am looking for 3-4 stops in a gym shooting basketball, but in a hockey arena, I am often only 1-2 stops away from ideal (found some shots I took in action mode, where the camera chose 7.1, 1/250 and 1600, and realized that I could try going with 400 or 800 and AV mode with my current set-up). My kids play WAY more hockey than basketball, fwiw.
I think with all my options that the T5i is still a good idea. As ebiggs said, "A 18MP sensor made 7 years ago will not be as good as a 18MP made in 2015. Things just get better"
That statement rings true to me. I am also a cyclist, and we know that components also improve to the point where the current midrange 105 is probably better than 5-6 year old top of the line Dura Ace.
I have Aftershot Pro 2.0, but haven't really used it much yet, and have only shot in RAW a few times (never inside iirc), but maybe that could also be part of the solution.
04-04-2015 04:36 PM
A couple of points. Your XSi doesn't have an 18mp sensor made 7 years ago. It has a 12.2mp sensor. Also, I think the T3i and the T5i have the same (18mp) sensor. AFAIK, the T6i and T6s are the first Rebels since the T2i to get a new sensor.
04-04-2015 05:33 PM
04-04-2015 09:32 PM
