10-14-2016 11:55 AM
Hello...
Just got a T6i.
When charging, is the charger supposed to blink orange/yellow or should it stay a solid color?
When first putting the battery on the charger out of the box, how long does it take to fully charge?
My camera is a canon factory refurb, and I cannot tell if the battter or charger is working correctly. I've contacted
canon tech support. One rep said the charger should remain a solid color another said it should blink till the charge light
turns green.
Please let me know....
Thanks
10-14-2016 12:24 PM
@RT87 wrote:Hello...
Just got a T6i.
turns green.
Thanks
While I have not used the T6i charger, every other Canon charger that I have used blinks red/orange until it turns to a steady green color, which indicates a full charge.
How long does it take? An initial charge may take a few hours, or even overnight. After that, 2-4 hours should do it.
10-14-2016 03:20 PM - edited 10-14-2016 03:20 PM
Thanks...
I think Canon sent me a bad battery with my camera.
Its been charging for about 10 hours. Still blinking. I figured it should have at least enough juice
to turn the camera on by now....no dice.
I've called them and they are sending a new one.
Thanks for your reply!
RT87
10-14-2016 04:10 PM
Just got a T6i.
turns green.
Thanks
With most Canon chargers the blinking pattern tells you how the charging process is progressing. One blink means it's just getting started; two blinks means about halfway; three blinks means 3/4 done; steady light (with or without a change of color) means fully charged.
10-17-2016 07:53 PM
Hello...
Just received my new battery.
When the battery is in the charger, it stays solid orange until it flips to green.
At least I know my new T6i works just fine!!
10-18-2016 09:41 AM
Mine stays yellow, too. Just tried it this morning.
