06-25-2023 10:59 AM
A quick question just got iOS on my Pro Max 14 version 17 and I can’t hook up my Canon EOS80D for nothing. I tried for two hours yesterday going through all the normal procedures which would be resetting restarting getting different sets to sign on different passwords. you name it it’s just not picking it up Canon Connect to down load my pictures ,
strange after five years to go through all this at this point just wanna know if it’s anyone else with iOS 17 or should I just wait for an update
06-25-2023 11:04 AM
iOS 17 is not yet released to the public. It's currently in beta. I would highly recommend using a non-pre-release OS (as of this writing, the latest version is iOS 16.5.1)
06-25-2023 11:04 AM
06-25-2023 11:27 AM
thank you so much I will try getting the 16.5. It could if I could go backwards. Perhaps I had the beta version checked off and they downloaded it to me you are correct give me a couple days to work on it.thank you so much I will try getting the 16.5. It could if I could go backwards. Perhaps I had the beta version checked off and they downloaded it to me you are correct give me a couple days to work on it
06-25-2023 11:36 AM
To revert to a non-beta OS, you can refer to this Apple Support article. If you don't have a Mac, it may be possible to restore using the iTunes application on a Windows PC.
