12-18-2014 04:03 PM
Hi My 650D does not display a picture on the LCD when you take a photo it does in liveview tho ?? also if i press the picture review button it brings it as normal up but no matter what setting i use for LCD display 2sec 4 8 or hold etc it will still not display the picture on the LCD as you take it (for review and quick check on exposure etc) i have reset evrything possible removed battery etc any ideas ??? much appreciated thanks
12-18-2014 04:18 PM
You may have your screen turned off. Try pressing Info button.
12-18-2014 04:34 PM
Hi problem solved
the LCD auto off option was enabled i canceled that and now the picture displays thanks
12-18-2014 04:56 PM
Hi all the real problem was this...
The issue was that the wee rubber eye piece around the viewfinder had slipped out of its seat slightly and was covering the sensor for the LCD. I Just checked the rubber eye piece bit pushed right down till it clipped into place and now not obstructing the LCD sensor as the picture displays both with the LCD auto off enabled or disabled !! simple thing but a massive trap !
12-18-2014 05:11 PM
Good catch - it thought the camera was against your face.
