Eos 5d mk iii lcd not working properly
ricosurfcat
The lcd on my eos 5d mkiii is suddenly not working properly. It displays the menu, info, Q button, and images. It will not display wb, af, iso, or af point select from the buttons on the body like it used to.
Tronhard
VIP
VIP
Under the third screen in the Wrench Main Menu, if you select INFO button options, what is set there?  If not all, then check all of the options, and then when you have returned to the normal operation mode, does that work now with repeatedly pressing the INFO button?
cheers, TREVOR
The mark of good photographer is not what they hold in their hand, it's what they hold in their head;
3 REPLIES 3
Tronhard
VIP
VIP
cheers, TREVOR
I had looked at that previously. All 3 options were checked. For giggles l unchecked the first 2, the 3rd would not uncheck. Fixed! Thanks so much!
jrhoffman75
Are you perhaps in an SCN or icon mode that doesn't allow those settings to be changed?
Avatar
